Thread: Crafter starting cranks
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: Crafter starting cranks
    #21
    Nov 2006
    6 months on with new battery, and it being a little colder, and city driving - its doing it all again, I have given the battery a 12 hour charge, but that only helped for a few days ... any ideas to try diagnose please ??
  2. Re: Crafter starting cranks
    #22
    Nov 2006
    Crewe, Cheshire
    43 Post(s)
    6 months on with new battery, and it being a little colder, and city driving "
    If the battery isn't getting sufficient charge between starts, you could be back to square one, & the battery just needs a top-up charge every now & then.
    You really need at least 2 miles of running to recharge the battery after a start & possibly more, depending what electrical load like blower on full & heated this & that.
    You really need to do the voltage checks again as per page 1.
  3. Re: Crafter starting cranks
    #23
    44 Post(s)
    993 Post(s)
    I think your alternator is incapable of keeping up, private message me your REG so I can look it up.
    If you care about the future of the planet, read this and watch the video
    https://www.bosch.com/stories/synthetic-fuels
  4. Re: Crafter starting cranks
    #24
    Nov 2006
    Have sent crasher the Reg no.
    Its making all urban journeys, to site in the morning is 2 miles, in traffic, beetling around during the day for 2-4 miles trips, 2-3 times a day, then back home at end of day.
    I presume new out of the factory - regardless of whether the van is driven with the above driving pattern, it would keep charge ? or do you need to put a new van on charge every so often.
  5. Re: Crafter starting cranks
    #25
    44 Post(s)
    993 Post(s)
    It was built with a 72AH/380A battery which is VAG number 000 915 105 DG and the old BBMA number would be 096 so the direct cross reference from OE to Euro Car Parts is an S4 008; using my favorite battery make a Yuasa 3096 ALTHOUGH I like to use the AGM 9096 in vehicles that do a lot of stop/start driving. The original alternator is 110A so should be able to cope but could have a Bosch or Valeo alternator, the latter of which is known for going weak. I think it is possible to just bolt on the 140A or even 180A alternators as all the mountings and drives appear from a check check to be the same, even the alternator harness. I would try and find a Bosch 0 986 081 230 from a company that does not demand a huge surcharge as you cannot supply a like for like old unit.
  1. Please Help Car intermittently not starting, cranks fully (S4 B6)
    By gurpreet94 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-07-2017, 09:52 PM
  2. Please Help VW Crafter 08 Reg Starting Issue
    By HelpwithCrafter in forum The Commercial Range
    Last Post: 11-06-2015, 08:56 PM
  3. Trouble starting - cranks but does not start
    By VWGEEK in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2014, 10:49 PM
  4. Cranks but won't start
    By thevagcr in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2012, 03:24 AM
  5. Question passat 130 cranks but won't run
    By Roger Lord in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-12-2010, 08:19 PM
