Thread: Change crank sensor at same time as cambelt?
  1. Change crank sensor at same time as cambelt?
    May 2020
    Manchester
    Apperently it won't hurt not to whilst the belt is being changed (at no extra cost). Does this sound right or is it asymptomatic of another issue wih the sensor itself?
    Garage is doing this presale and mentioned the sensor.
    Sounds very nice of them if there's nothing hidden.
  2. Re: Change crank sensor at same time as cambelt?
    1836 Post(s)
    The belt is at one end of the engine and the crank speed sensor (G28) is at the other buried inside the bell housing behind the flywheel covered by the oil filter bracket so either they mean the camshaft position sensor G40 which is behind the belt pulley or they are worried it has a G28 problem which is very common and evil to change with a nasty clock up potential.
  1. a4 2.0 avant tdi crank sensor change
    By bobcottam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-12-2015, 04:56 PM
  2. Replies: 0
    Last Post: 07-12-2015, 04:17 PM
  3. Time For Cambelt Change, Where Do You All Go?
    By Sti_Prodrive in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2014, 11:02 AM
  4. Cambelt Change Time: Specialist Job?
    By as400 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2013, 07:27 PM
  5. Is it time to change the cambelt
    By thewall in forum Golf MK5 - 2004 - 2009
    Last Post: 10-11-2009, 06:08 PM
