Thread: Passat will not start, not even turn over
Results 1 to 8 of 8
  1. Passat will not start, not even turn over
    Nov 2018
    Tamworth
    22 Post(s)
    Hi all.
    2008, 1.9 TDi diesel estate.
    After my recent adventures when she just died she now won't even turn over.
    When I push the key I just get a "Zizzzzz" noise from somewhere behind the dash.
    I've tried a different, fully charged, battery and that makes no difference.
    The usual warning lights come on, then go out (including the electric "steering" one) but then nothing except this "Zizzzzz" noise.
    The VCDS log looks horrendous to me with lots of code 1100, cannot be reached.
    A hunt around some of the codes suggests relays (poss starter motor) &/or fuses.
    Is it multimeter time?
    Hopefully someone can point me in the right direction to get her sorted.
    Thanks in advance
    Andy.
    VCDS log:
    Code:
    Thursday,14,May,2020,18:47:21:34600
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    Data version: 20200331 DS317.0
    Ross-Tech: Home
    VIN: WVWZZZ3CZ8E*****   License Plate: LO08***
    Mileage: 225580km-140168mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ8E*****   Mileage: 225580km-140168miles
    01-Engine -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    16-Steering wheel -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Cannot be reached 1100
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Cannot be reached 1100
    56-Radio -- Status: Cannot be reached 1100
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes
    Cannot be reached
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 77AA1DCFF3C53633621-8022
    3 Faults Found:
    00819 - High Pressure Sensor (G65)
                009 - Open or Short to Ground
    01316 - ABS Control Module
                004 - No Signal/Communication
    01314 - Engine Control Module
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Component: Bordnetz-SG     H54 2202
       Revision: 00H54000    Serial number: 01000008124400
       Coding: 00888F0700041A00470A00000F000000000859435C000100000000000000
       Shop #: WSC 05124 000 00000
       VCID: 71BE23D79DA16803AC5-8024
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 130208 022  0601
       Coding: 00046997
       Shop #: WSC 05124
    5 Faults Found:
    02403 - Terminal 15 for Interior
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 2
                        Fault Frequency: 6
                        Reset counter: 44
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:46:00
                 Freeze Frame:
                            ON
                        Voltage: 12.30 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01049 - Supply Voltage Term 50
                 Freeze Frame:
                        Fault Status: 01111100
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 225589 km
                        Time Indication: 0
                        Date: 2020.05.11
                        Time: 00:00:00
                 Freeze Frame:
                            ON
                        Voltage: 12.15 V
                            OFF
                            ON
                            ON
                            OFF
                            OFF
    01321 - Control Module for Airbags (J234)
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 6
                        Reset counter: 44
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:46:00
                 Freeze Frame:
                            ON
                        Voltage: 12.30 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 225589 km
                        Time Indication: 0
                        Date: 2020.05.11
                        Time: 00:00:00
                 Freeze Frame:
                            ON
                        Voltage: 12.15 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01309 - Power Steering Control Module (J500)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 225589 km
                        Time Indication: 0
                        Date: 2020.05.11
                        Time: 00:00:00
                 Freeze Frame:
                            ON
                        Voltage: 12.15 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    Address 15: Airbags
    Cannot be reached
    Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
       Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C9953507AT
       Coding: 0000112
       Shop #: WSC 05311 000 00000
       VCID: 6FBA25AF8B957EF3BA1-803A
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           002 0010
    1 Fault Found:
    Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
       Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 00657 067 57207
       VCID: 270A0D8F63E566B3321-8072
    No fault code found.
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P0822301F1
       Coding: F9807F060002022003
       VCID: 2312199F17DD8A936E9-8076
    2 Faults Found:
    01305 - Databus for Infotainment
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 36
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:37:37
    01304 - Radio
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 36
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:37:42
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 392EDBF78551E043545-806C
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    1 Fault Found:
    02828 - Enabling Steering Column Lock from Diagnostic Interface
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 4
                        Fault Frequency: 10
                        Reset counter: 84
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:46:30
    Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
       Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
       Component: J386  TUER-SG FT    1132
       Revision: 32008001    Serial number: 00000115788224
       Coding: 0000693
       VCID: 3B22C1FF8F6DD253469-806E
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
                005 - No or Incorrect Basic Setting / Adaptation
                 Freeze Frame:
                        Fault Status: 01100101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:37:37
    Address 44: Steering Assist
    Cannot be reached
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 042 0472
       Coding: 0191020051030E763004941570085FCE107C01
       Subsystem 1 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H08 9001
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 225589 km
                        Time Indication: 0
                        Date: 2020.05.11
                        Time: 00:00:16
    00625 - Vehicle Speed Signal
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 225589 km
                        Time Indication: 0
                        Date: 2020.05.11
                        Time: 05:50:18
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1132
       Revision: 32008001    Serial number: 00000527688216
       Coding: 0000692
       VCID: 3C20C2E38A63D56B4F3-8068
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
                005 - No or Incorrect Basic Setting / Adaptation - Intermittent
                 Freeze Frame:
                        Fault Status: 00100101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 81
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:37:37
    Address 53: Parking Brake
    Cannot be reached
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000235473
       Coding: 0000144
       VCID: 70B826D396AB610BA3B-8024
    Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000243339
       Coding: 0000144
    End----(Elapsed Time: 02:34, VBatt start/end: 12.3V/12.2V. VIgn 0.0V)------
  2. Re: Passat will not start, not even turn over
    1836 Post(s)
    I would suspect the line 15 relay, I could tell you what and where if you hadn't deleted the VIN serial.
  3. Re: Passat will not start, not even turn over
    Nov 2018
    Tamworth
    22 Post(s)
    PM sent.
    Andy.
  4. Re: Passat will not start, not even turn over
    1836 Post(s)
    I really need to be at work with the diagram in front of me but your description suggest the line 15 relay (or its trigger circuit) has failed so if you bridge the power terminals of location KL15, the ignition should power up.
  5. Re: Passat will not start, not even turn over
    Nov 2018
    Tamworth
    22 Post(s)
    Thanks Crasher,
    You're a genius
    Took the relay out and bench tested it - all apparently OK. Heard "clicking" when 12V applied across terminals 85 & 86.
    Happy lit up a bulb put into a circuit across terminals 87 & 30.
    Nothing except the the Zizzz noise when plugged into the car. Determined that it was the relay making the noise by contorting a finger onto it while depressing the clutch and pushing the key.
    Took the relay out and bridged 87 & 30 on the relay board itself and Hey Presto she starts and runs.
    Replacement ordered and we'll see if that does the trick.
    Totally confused how a relay that does what you expect on the bench does diddly squat when plugged into the car. Modern electrics/electronics I guess.
    Thanks again.
    Andy.
  6. Re: Passat will not start, not even turn over
    1836 Post(s)
    Quote Originally Posted by AndyN01 View Post
    Thanks Crasher, You're a genius
    nope, just a hard fought battle against not being able to understand mathematics but refusing to give in.
  7. Re: Passat will not start, not even turn over
    Nov 2018
    Tamworth
    22 Post(s)
    Crasher - 1
    Non starting Passat - 0
    Replacement "460/B1/KL15" relay fitted and..... She start, runs and all seems fine. .
    Crasher, you're a star.
    Andy.
  8. Re: Passat will not start, not even turn over
    1836 Post(s)
    I have had two Golf 7’s do this now, the relay is behind the glovebox so anyone who has done a Golf 7 cabin filter will have seen it. The symptom is nearly but not completely dead electrics with multiple ECU comms failure when doing a scan. Oddly both cars had damp and mould problems and on both the relay was covered in condensation. I have also had a few Caddy, Golf Plus and Touran’s (both in the workshop and helping other garages over the phone) respond to jumping the relay but a new relay doesn’t work and it is the Body Control Module not commanding the relay.
  1. 2012 Passat 2.0 TDI sport will not start or turn over
    By geoff10 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 13-08-2020, 02:44 PM
  2. Passat TDI BMT will not start or turn over - odd things happening!
    By jamesmerrix in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 08-01-2017, 03:56 PM
  3. 98 cab won't turn to start
    By greasegun in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-11-2009, 03:33 AM
  4. Please Help passat mark 5 , wont turn over , wen jump start, lights dont work
    By Al_Killya in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-10-2009, 02:38 PM
  5. 96 A4 will not turn over(start)
    By SeanyA41.6 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-07-2009, 10:32 PM
