Thread: RSN-E weird Sat Nav fault
  1. RSN-E weird Sat Nav fault
    May 2009
    Saddleworth, Yorkshire
    I have a 2010 TT with the RSN-E HU & MFSW, a year ago I purchased a 7 digit postcode disc from the SatNavi shop that has worked with no issues all this time until yesterday, whilst out following the sat nav the following happened :-
    The DIS returned to my speed rather then directions, followed shortly by the sat nav not providing any info.
    Then a message saying no dvd/disc found, I pressed the disc eject button and nothing happened, the screen would also not fold away, the radio was still working but none of the selection button on the HU worked.
    When I stopped the car and turned off the ignition, still nothing and the screen was open.
    I returned to the car about thirty mins later and the screen had closed, I removed the sat nav disc and the HU worked perfectly.
    I put the nav disc back in and set the sat nav for my return trip within 2 minutes the above happened again, during my drive home the sat nav announced - planning route, I pressed eject and the disc came out. The HU then worked perfectly.
    Upon getting home I re-installed the 2010 gen Audi disc that came with the car and it works fine - weird or what
    Could this fault have been caused by a non-genuine Audi disc (that has worked fine for over a year) or could it be something else ?
    Many thanks for any suggestions - Ian Simkins
  2. Re: RSN-E weird Sat Nav fault
    1836 Post(s)
    Original battery?
  3. Re: RSN-E weird Sat Nav fault
    May 2009
    No, I fitted a new one 2 months ago.
    Thanks ian
  4. Re: RSN-E weird Sat Nav fault
    1836 Post(s)
    You need a diagnostic scan of the head unit BUT it may need to go on the VAG system ODIS for a Software Version Management check.
  5. Re: RSN-E weird Sat Nav fault
    May 2009
    Thank you for your advice
    Ian
  6. Re: RSN-E weird Sat Nav fault
    Jan 2024
    Weymouth, England
    Suggestion: visit RNS-E Firmware | Home and pay for the very modest upgrade which will allow you to put the maps on SD card.
    No connection except as happy customer.
    jez
  1. Weird rev fault and BOSE system not doing ewt!
    By daveoholt in forum A8 - S8 - V8
    Last Post: 28-01-2013, 08:33 AM
  2. Question Weird electrical fault - any clues
    By Rpw001 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-05-2012, 05:11 PM
  3. Weird Fault
    By JamesMo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-08-2010, 03:27 PM
  4. Please Help weird fault
    By zedy1 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2009, 11:57 PM
  5. Weird fault
    By kasper17 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2008, 12:54 PM
