Thread: A3 2.0 Tdi steering rack advice
  1. A3 2.0 Tdi steering rack advice
    Apr 2017
    wirral
    Hello guys my steering assist only starts working after about ten minutes driving and I have just found one in a friends breakers yard..car is same year and same model,question is would that definitely be a match for my car and is there any coding that would have to be done or is it just a case of fit it and drive away happy ,thanks in advance
  2. Re: A3 2.0 Tdi steering rack advice
    1840 Post(s)
    It can be a straight swap but can easily turn into a nightmare.
  3. Re: A3 2.0 Tdi steering rack advice
    Apr 2017
    wirral
    Hmmm the old thing is running so good after the nightmare I am thinking about tackling the steering as my arms get a bit wiped out after a good day on the trowel, I have had a look at a few posts about marking up and dropping subframe but what kind of nightmare am I looking at,is it part comparison or coding /fitting
  4. Re: A3 2.0 Tdi steering rack advice
    1840 Post(s)
    It is the not just the coding and adaptation that can be the sketch, there are three different racks designs (and dozens of variations to each) where some are a straight swap, others need a harness and others half the subframe as well. It can be easy, it can be awful. To help I would need you to PM me your reg number and also a scan of the rack ECU memory.
  5. Re: A3 2.0 Tdi steering rack advice
    Apr 2017
    wirral
    Thanks crasher I fitted a 2nd gen today and fortunately for me it was a straight swap over and it’s working great just need to get tracking sorted ,thanks again.
    1 1 0
  1. Steering gear fault. Steering rack box knocking noise
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-08-2020, 06:46 AM
  2. Replacement Steering Rack has changed steering
    By xandertarr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-04-2017, 10:46 AM
  3. Polo steering pulling to the left after steering rack change
    By Jk2 in forum Polo - Derby - Lupo - Fox
    Last Post: 03-12-2013, 01:07 AM
  4. Please Help 6N1 Polo leak in power steering pipe from pump to steering rack
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2012, 08:36 AM
  5. Advice needed - possible steering rack / cv joint / gear box problem
    By angel18082005 in forum Chat - Anything with wheels
    Last Post: 13-09-2007, 06:55 PM
