Thread: a3 electric steering not working
  1. a3 electric steering not working
    May 2020
    GB
    Hi guys i have a problem with steering. customer came for replacing track rod ends so we replaced and then lift car down and steering assist stopped working. checked all the fuses under bonnet,and offside panel looks good. checked wiring positive negative and plugs they are all fine.. vcds shows two same errors rotation pressure sensor. ABS unit shows code no communication with J700 unit which is steering rack. so I've replaced steering rack and its still the same problem... anyone can help me please?
    Sent from my SM-A505FN using Tapatalk
  2. Re: a3 electric steering not working
    1837 Post(s)
    The light often comes on if the car has been in the air and maybe the battery off so did you try setting it up by driving around the block first and a few stationary lock to locks? Which generation rack is it, 1, 2 or 3 and which year? Whose rack is it, used, genuine, Bosch or Shaftec? Depending on the generation the set up is done in the rack controller or the ABS.
  3. Re: a3 electric steering not working
    May 2020
    GB
    yes I've try'd driving and lock to lock as well no joy... steering rack pic included.
  4. Re: a3 electric steering not working
    1837 Post(s)
    That is an internal number not the number of the rack, 906 middle number means an ECU, the rack would be something like 1K2 (i.e.PQ35 platform) 423 (front axle, steering gear) 055 and then a letter and there are a number of suffixes such as A, B, C, F, AL, AG, AA etc etc.
  5. Re: a3 electric steering not working
    Mar 2016
    Minervois, France
    53 Post(s)
    The middle number is 909, not 906
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  6. Re: a3 electric steering not working
    1837 Post(s)
    I can't read upside down when I am sober, and I can't edit things without cocking it up either
  1. Question A4 b7 electric windows working then not working
    By Jobas77 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-02-2017, 03:09 PM
  2. audi a8 2007 electric steering stopped working!!!
    By vwpassat in forum A8 - S8 - V8
    Last Post: 06-09-2014, 02:11 PM
  3. Steering Wheel Electric not working
    By davrostavros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-07-2012, 01:42 PM
  4. Electric Seats Not Working!
    By FLASH in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-09-2009, 06:46 PM
  5. electric mirrors not working
    By duanvogel in forum Vento - 1994 - 1998
    Last Post: 23-06-2009, 11:19 PM
