Thread: Help needed resetting pelectronic park brake after new discs and pads.
  1. Help needed resetting pelectronic park brake after new discs and pads.
    May 2020
    Burton on Trent
    Hi everyone, a newbie here, just changed the rear discs and pads on my 2014 Touareg, i borrowed an Autophix diagnostic scanner to disable the epb but i am struggling to reset it after the install. i had a battery charger connected the whole time to keep the voltage stable.
    could someone please run through the grinding in and reset process for me.
  2. Re: Help needed resetting pelectronic park brake after new discs and pads.
    May 2020
    Burton on Trent
    Should say electronic park brake, doh.
  3. Re: Help needed resetting pelectronic park brake after new discs and pads.
    108 Post(s)
    1816 Post(s)
    It is a sketch. You have to precisely set the brake shoe to drum air gap and then complete a very difficult burning in procedure, I can just about find the space to do it around our local park and ride for the tram on the Goose Fair site but it is awkward. So far I have failed to complete the procedure with VCDS or VCP, the only systems I have had success with are my friends Delphi unit and my own ODIS system... if and when it works!
  4. Re: Help needed resetting pelectronic park brake after new discs and pads.
    May 2020
    Burton on Trent
    Thanks Crasher, what do you charge to do it ? Are you in Nottingham?
  5. Re: Help needed resetting pelectronic park brake after new discs and pads.
    108 Post(s)
    1816 Post(s)
    Yes we in Nottingham, I won't be able to do it for a few weeks at least.
  1. new front pads & discs needed
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-09-2014, 09:46 PM
  2. New brake pads AND discs for the rear - needed?( 56 plate)
    By Dr Mcr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-01-2012, 04:04 PM
