Thread: 2004 Touran 1.9 TDI Turbo Adjustment
  1. 2004 Touran 1.9 TDI Turbo Adjustment
    Jul 2007
    I bought a Touran 1.9 TDI off a friend after the turbo packed up. I took the old turbo off and was surprised to find that the impeller shaft had actually snapped and the turbine was in the cat of the exhaust.
    I got a good replacement from another Touran (matching part numbers) and fitted it. All is great and drives fine but it seems to be a little short on Torque when pulling away as if the turbo is not providing the boost and needs adjusting slightly.
    Is there a specified adjustment for this and can anyone tell me what it is or advise on the chapter on Elsa please.
    Thanks for any help.
  2. Re: 2004 Touran 1.9 TDI Turbo Adjustment
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    When we were choosing our Touran we drove both the 2.0 and 1.9 TDIs. The 2.0 felt like it had a lot more oomph, so could it just be that? Also things like no brakes dragging a bit and getting hot?
    There are other threads about non-adjustability of turbo due to the fine balance of the actuator control, although you can try of course...
    Does the actuator slide smoothly, ideally when tested with a vac pump?
  3. Re: 2004 Touran 1.9 TDI Turbo Adjustment
    Jul 2007
    Thanks for the reply.
    Everything else is tip top on the Touran as it was serviced by a friend of mine who owns a garage and looked after it from when it ran out of warranty. Its definitely turbo related. It just seems like the vanes are not adjusted correctly and letting the exhaust pressure out instead of spinning up the turbo.
    Its only on pull away too( low revs ) as all other times is fantastic and there are no fault codes in the system with both VCDS and Autel.
  4. Re: 2004 Touran 1.9 TDI Turbo Adjustment
    108 Post(s)
    1816 Post(s)
    The actuator is set up off the car on a flow rig.
  5. Re: 2004 Touran 1.9 TDI Turbo Adjustment
    Jul 2007
    Thanks for your reply.
    Has to be set up professionally then?
  6. Re: 2004 Touran 1.9 TDI Turbo Adjustment
    108 Post(s)
    1816 Post(s)
    Yes, Midland Turbo do it for us when they do a rebuild, good people.
  1. 2004 B6 S4 rear camber adjustment
    By charlie wade in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-05-2015, 11:01 PM
  2. Please Help Touran Headlamp adjustment for France
    By Sullydog in forum Touran - Sharan - Caravelle
    Last Post: 26-08-2014, 04:19 PM
  3. 2004 touran turbo
    By capt-flatout in forum Touran - Sharan - Caravelle
    Last Post: 01-09-2011, 02:51 PM
  4. Turbo Acuator Length adjustment on VNT TURBO on 1.9 Sharan
    By sharan1.9 in forum Touran - Sharan - Caravelle
    Last Post: 13-12-2010, 05:36 AM
  5. Question Turbo Seal 1.9 TDI 2004 Touran
    By dieseldes in forum Touran - Sharan - Caravelle
    Last Post: 09-09-2009, 09:51 PM
