Thread: Basic settings golf 7 2013 model
  1. Basic settings golf 7 2013 model
    May 2020
    Crete
    Hi to all.. i want ti restore my basic settings to 042 module of driver door..
    All the switches is dead...but everything work from outside with the key fob...mirror folding, windows are opening and lock normally...😞
  2. Re: Basic settings golf 7 2013 model
    Aberdeen
    63 Post(s)
    I have moved your thread to the correct section.
  3. Re: Basic settings golf 7 2013 model
    May 2020
    Crete
    Code:
    Tuesday,05,May,2020,10:34:34:00009VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 19.6.1.0
    Data version: 20190529 DS308.0
    www.Ross-Tech.com
    VIN: WVWZZZAUZDW116004   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZDW116004   Mileage: 120932km-75143miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 AC    HW: 04E 907 309 G
       Component: 1.4l R4 TSI   H02 5533
       Revision: WKH02---
       Coding: 01190012232405082000
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_ECM14TFS01104E906016AC 002006
       ROD: EV_ECM14TFS01104E906016AC.rod
       VCID: 63C51A8B6A55B157E4-8036
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
       Part No SW: 5Q0 614 517 CL    HW: 5Q0 907 379 D
       Component: ESC           H75 0438
       Revision: 00000000    Serial number:
       Coding: 01FA6AA120212A720377060001C72980560454C0608094F300280028C0
       Shop #: WSC 131071 1023 2097151
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
       ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
       VCID: 7DF14CF3ECF167A7F2-8028
    Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
       Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
       Component: Climatronic   H02 0503
       Revision: 00001K06
       Coding: 00020004200100011005004000101000
       ASAM Dataset: EV_ACClimaBHBVW37X 002017
       ROD: EV_ACClimaBHBVW37X_002_VW37.rod
       VCID: 356194D394417FE77A-8060
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
       Component: BCM MQBAB M   H14 0106
       Serial number: 00011306600200
       Coding: 00000842C24102FB4FE4400011040328100A000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 010001
       ROD: EV_BCMBOSCH_010.rod
       VCID: 4385FA0BCA95D157C4-8016
       Control Unit For Wiper Motor:
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    130213  042 0551
       Serial number:         130225134320
       Coding: 0E4DF5
       Rain Light Recognition Sensor:
       Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0004
       Serial number: 63352462
       Coding: 27A8DD
       Alarm horn:
       Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Component: Sirene, DWA  004 0311
       Serial number: 00000000000027718315
    Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
       Component: AirbagVW20    011 0361
       Serial number: 003M1R01YZSM
       Coding: 98CCC000000000005C0000CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4A9BD72FEDBF001F07-801E
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169667A05031370402
       Coding: 333135
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169668A05031340454
       Coding: 333135
       Side Sensor Driver Front:
       Subsystem 3 - Part No SW: -----------    HW: 480 002 602 13
       Component: SideSensor_Df  001 0887
       Serial number: 35767000000A7235DC0.
       Coding: 2D2D2D
       Side Sensor Passenger Front:
       Subsystem 4 - Part No SW: -----------    HW: 480 002 602 13
       Component: SideSensor_Pf  001 0887
       Serial number: 3586700000082335DC0W
       Coding: 2D2D2D
       Side Sensor Driver Rear:
       Subsystem 5 - Part No SW: -----------    HW: 480 402 502 13
       Component: SideSensor_Dr  001 6149
       Serial number: 3516502990F8ABF4228T
       Coding: 2D2D2D
       Side Sensor Passenger Rear:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 502 13
       Component: SideSensor_Pr  001 6149
       Serial number: 3526502C10F76B11C2BG
       Coding: 2D2D2D
       Front Sensor Driver:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 902 13
       Component: FrontSensor_D  001 6149
       Serial number: 35565029D0F8F7F560B1
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Component: Lenks. Modul  007 0070
       Revision: --------    Serial number: 01031304220134
       Coding: 0400
       Shop #: WSC 40195 333 37120
       ASAM Dataset: EV_SMLSKLOMQB 009001
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 75E154D3D4C13FE7BA-8020
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
       Part No SW: 5G0 920 860     HW: 5G0 920 860
       Component: KOMBI         235 0555
       Coding: 03A501002380000801083A00040000
       ASAM Dataset: EV_DashBoardVDDMQBAB 008026
       ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
       VCID: 65C104936461CF670A-8030
    Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
       Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
       Component: GW MQB Mid    124 1109
       Revision: --------    Serial number: 0000398803
       Coding: 030100042B086400FF00024C080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 3365AACB9A3561D754-8066
       Alternator:
       Multi Function Steering Wheel Control Module:
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H14 0035
       Serial number: 02130000610120040291
       Coding: 280000
       Battery Monitoring Control Module:
       Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Component: J367-BDMHella  H03 8042
       Serial number: 9221130103
    Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 25021304080547
       Coding: 003F0320D000048000001000
       Shop #: WSC 00046 123 12345
       ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
       ROD: EV_DCUDriveSideEWMAXCONT.rod
       VCID: 3F8DF6FBA67DB5B7A0-806A
       Drivers Door Rear Control Module:
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG DRV  007 0002
       Serial number: 00000000000000876772
       Coding: 010000
    2 Faults Found:
    65604 - Door Warning Lamp
              B1326 01 [009] - Electrical Failure
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 107
                        Mileage: 120932 km
                        Date: 2020.05.04
                        Time: 10:26:54
    65649 - Lamp for Ambient Illumination
              B1325 13 [009] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 107
                        Mileage: 120932 km
                        Date: 2020.05.04
                        Time: 10:26:54
    Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
       Component: EPS_MQB_ZFLS  119 1021
       Coding: 81
       ASAM Dataset: EV_SteerAssisMQB 008022
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D718CF3AC71A7A7B2-8068
    Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 23021303111002
       Coding: 003F0120DC00048000801000
       ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
       ROD: EV_DCUPasseSideEWMAXCONT.rod
       VCID: 3E738BFFA177BCBFAB-806A
       Passengers Rear Door Control Module:
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG PSG  007 0002
       Serial number: 00000000000000866525
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
       Component: MU-S-ND-ER    840 0757
       Serial number:
       Coding: 02730001BE0000005111010140880A525F01009571A00100CF
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_MUStd4CDELP 001001
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 3169A0C3602953C726-8064
       Operating And Display Unit 1:
       Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
       Component: ABT_Std-2  H50 8130
       Serial number: VWZ6ZJT2516002
       Data medium:
       Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
       Component: ECE AS 20/21  --- 1430
       Serial number: --------------------
    4 Faults Found:
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 104
                        Mileage: 120899 km
                        Date: 2020.05.03
                        Time: 09:43:49
                        Voltage terminal 30: 12.1 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
    1555 - Check Software Version Management
              B201A 00 [009] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 104
                        Mileage: 120899 km
                        Date: 2020.05.03
                        Time: 09:43:49
                        Status_Software_Version_Management-module_name: C
    0013 - Antenna Amplifier 1 for Digital Radio
              B1270 13 [009] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 104
                        Mileage: 120899 km
                        Date: 2020.05.03
                        Time: 09:43:50
                        Status of digital radio antenna 1-Antenna current: 0 mA
                        Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                        Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 3.357312
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 2.632250
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 104
                        Mileage: 120899 km
                        Date: 2020.05.03
                        Time: 09:43:53
                        BAP-BAP_Function_ID: 02
    End-------------------------(Elapsed Time: 03:17)--------------------------
    Last edited by Arxo-manolis; 05-05-2020 at 08:35 AM. Reason: 05f is hucked mib2 for that reason it has fault
  4. Re: Basic settings golf 7 2013 model
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    It's reporting electrical failures. Have you looked at the wiring in the rubber boot that connects door to body? Maybe had water in there - window down while raining which lets it trickle in via top slot?
  5. Re: Basic settings golf 7 2013 model
    May 2020
    Crete
    its clean..on the measuring block the switches of windows lock and mirror says not acivated...
  6. Re: Basic settings golf 7 2013 model
    May 2020
    Crete
    i have 2 new door module, they need flash? or only coding?
  1. Please Help 02e DSG basic settings
    By bridans in forum Octavia
    Last Post: 23-07-2019, 09:19 AM
  2. Please Help Old how can I do basic settings dsg ocw
    By maoyekanmi in forum 2.0T, TSI and TFSI - Engine
    Last Post: 27-11-2017, 05:54 PM
  3. TT dsg basic settings
    By Jimmy2scoops in forum VCDS - Help Requests
    Last Post: 17-06-2009, 09:46 PM
  4. How To reset to basic settings
    By MK4 auto in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2009, 11:38 PM
  5. Basic Settings On Vag Com
    By cyberduderen in forum VCDS - General Questions
    Last Post: 31-01-2008, 12:03 AM
