Thread: Golf Gti 16V engine problem.
  1. Exclamation Golf Gti 16V engine problem.
    May 2020
    Grantham
    Hi i have a Golf Mk3 GTI 16V ABF Engine and the rev sticks at 2000 rpm sometimes it sticks at 3000 rpm both i have cleaned the throttle body and made sure it its closing fully and opening as it should.
    any help in this matter would be great.
  2. Re: Golf Gti 16V engine problem.
    1840 Post(s)
    You need to know if the ECU is seeing that the throttle is closed so it will engage idle speed control, the only way to do this is observe the values in measuring blocks using suitable diagnostic equipment. If you have a throttle closed switch fault, part number 037 133 093 G,then you will have huge problems buying a new one on its own and last year when I had this problem on a customers car, all I could suggest was a new throttle body unit from VW Classic, 037 133 061 BQ, at €649 plus postage.
  3. Re: Golf Gti 16V engine problem.
    May 2020
    Grantham
    thank you for the help much appreciated i will get it checked out
  1. Please Help - Golf GTI engine problem
    By pogangah in forum Golf MK4 - 1999 - 2004
    Last Post: 05-01-2009, 12:27 PM
  2. VW Golf 1.4 S Engine problem...help.
    By sgx in forum Golf MK4 - 1999 - 2004
    Last Post: 29-02-2008, 01:13 PM
  3. golf mk 3 engine problem
    By bitofaboyraver in forum Chat - Anything with wheels
    Last Post: 27-01-2008, 11:24 AM
  4. Golf Mk 4 GT TDI>>Engine problem
    By ray2002 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-11-2006, 12:16 PM
  5. Golf Ser.3 TD Odd Engine Problem
    By JVOB in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-01-2006, 12:22 AM
