Thread: 2002 1.9PD no power, P1556 code.
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. Re: 2002 1.9PD no power, P1556 code.
    #21
    Mar 2010
    Derry ireland
    59 Post(s)
    just check out map& maf earths map sensor earth terminal 1 > ecu 52 maf sensor terminal 3 ecu>49 these 2 earthing points say a lot
  2. Re: 2002 1.9PD no power, P1556 code.
    #22
    108 Post(s)
    1816 Post(s)
    It's whether the same underboost code is being stored that interests me.
  3. Re: 2002 1.9PD no power, P1556 code.
    #23
    Feb 2020
    Suffolk
    Just read the codes again, 17964 Charge pressure control: Negative deviation P1556 - 35-00 - -
    I'll meter out the earth wires tomorrow, I don't have a multimeter at home today.
    Thanks for all your input and help, much appreciated.
  4. Re: 2002 1.9PD no power, P1556 code.
    #24
    108 Post(s)
    1816 Post(s)
    There is something fundamentally wrong with your boost control systems vacuum circuit.
  5. Re: 2002 1.9PD no power, P1556 code.
    #25
    Feb 2020
    Suffolk
    I checked the earths to the MAP and MAF sensors, both are ok.
    The MAP sensor has 4.8V to pin 4 (ignition on, sensor plugged in). I have 5v to pin 2 with the MAP unplugged. I metered out pin 3 to 31 on the ECU all ok.
    The MAF sensor has 14.4v to pin 2 (engine running).
    I put a vac line from the servo line directly to the VNT actuator, thinking this would give me over boost, still no power at all.
    Could the new turbo in someway be faulty? it spins by hand. I did also have the lack of power just before changing the turbo but I put this down to the turbo being stuck solid.
  6. Re: 2002 1.9PD no power, P1556 code.
    #26
    108 Post(s)
    1816 Post(s)
    If you still have the original, send it to Midland Turbo for rebuild.
  7. Re: 2002 1.9PD no power, P1556 code.
    #27
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I know you've changed the MAP sensor, but have you checked in measuring blocks what the ECU is seeing from this sensor.
    Could be a wiring fault that is killing the MAP signal.
  8. Re: 2002 1.9PD no power, P1556 code.
    #28
    Feb 2020
    Suffolk
    Today I cleaned up and fitted a new cartridge to my old original turbo. I fitted it to the car, couldn’t see anything wrong with the (new) one that came off so not too hopeful.
    Only had time for a short test drive, but seems to be fixed! I’ll hopefully take it for a better run tomorrow, and inspect the turbo I removed a bit more thoroughly.
  1. Please Help Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    By mumutley in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2019, 11:10 PM
  2. Please Help p1556
    By willber6 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2010, 02:07 PM
  3. golf tdi S 90 BHP P1556 fault code, please help
    By gti203 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2008, 10:48 PM
  4. VW GOLF TDI S 90 BHP power loss P1556 fault code, please help
    By gti203 in forum New Member Introductions
    Last Post: 19-05-2008, 10:47 PM
  5. p1556 turbo pressure too low
    By milhouse in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-06-2006, 02:37 PM
