Thread: 2002 1.9PD no power, P1556 code.
Results 11 to 20 of 28
  1. Re: 2002 1.9PD no power, P1556 code.
    Feb 2020
    Suffolk
    This morning I removed and checked all the charge pipes. They all look ok, and no signs of oil being blown out. I rigged up a pressure tester, blanked off the pipe that enters the inlet manifold and pressurised from the turbo end. The system held pressure very well.
    I fitted a different n75 valve with a simplified routing with new pipes from the servo line to the new n75 then to the actuator.
    I also swapped the MAP sensor as I had one.
    Still the same, no difference at all.
  2. Re: 2002 1.9PD no power, P1556 code.
    1840 Post(s)
    Very thorough and very annoying! What are the part numbers of the Thrust sensor in there and the one before?
  3. Re: 2002 1.9PD no power, P1556 code.
    Feb 2020
    Suffolk
    The original one was 036906051C, I cant read the numbers on the one I fitted but it came of a 2003 Octavia 1.9pd and looked identical.
  4. Re: 2002 1.9PD no power, P1556 code.
    1840 Post(s)
    Well I hope you mean 038 906 051 C, not 036 906 051 C... they make look the same but they aren’t! There are two sensors used in a 2003 Octavia 1U PDTDI, 038 906 051 and 038 906 051 B which changed to D, again these look the same but certainly are not... and are not the same as the 038 906 051 C (Bosch 0 281 002 401 ) if they were that would be stupid of VAG, if they have different part numbers that can be a superseded part number but you should never assume that. Assumption is the Mother of all **** up’s... Incidentally the sensor you need is still available genuine but not from Bosch so it is either genuine or aftermarket.
  5. Re: 2002 1.9PD no power, P1556 code.
    Feb 2020
    Suffolk
    I'll double check part numbers tomorrow, they were from memory and numbers scribbled on a pad by my computer! Do you think the MAP sensor could be the fault? I have what seems to be no boost at all. Many thanks Michael
    Edit:-
    Part number of the original MAP sensor is 038 906 051 C
  6. Re: 2002 1.9PD no power, P1556 code.
    1840 Post(s)
    You need a new correct sensor to go any further, ECP have good stocks of the correct (going obsolete) Bosch 0 281 002 401.
  7. Re: 2002 1.9PD no power, P1556 code.
    #17
    Feb 2020
    Suffolk
    Hi, The new sensor arrived today, genuine Bosch, fitted it and had a drive, still the same, no power at all.
  8. Re: 2002 1.9PD no power, P1556 code.
    #18
    1840 Post(s)
    No power even from the start? Are you getting the same low boost fault code? To me it sounds like a classic faulty Air Mass Meter.
  9. Re: 2002 1.9PD no power, P1556 code.
    #19
    Feb 2020
    Suffolk
    No real power anyware. I just swapped the air flow meter with the one on the girlfriends golf, same part numbers 0 281 002 461.
    Still no difference. I cant read the fault codes at the moment, my old computer wont find the port for the cable, I'll hopefully borrow one tomorrow to check the codes.
  10. Re: 2002 1.9PD no power, P1556 code.
    #20
    1840 Post(s)
    We are missing something simple here, under ones nose...
  1. Please Help Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    By mumutley in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2019, 11:10 PM
  2. Please Help p1556
    By willber6 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2010, 02:07 PM
  3. golf tdi S 90 BHP P1556 fault code, please help
    By gti203 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2008, 10:48 PM
  4. VW GOLF TDI S 90 BHP power loss P1556 fault code, please help
    By gti203 in forum New Member Introductions
    Last Post: 19-05-2008, 10:47 PM
  5. p1556 turbo pressure too low
    By milhouse in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-06-2006, 02:37 PM
