Thread: Dpf questions
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. Re: Dpf questions
    #21
    Nov 2013
    west midlands
    Well it does as it’s in the software that it’s got one.
    I’m not too clued up on vagcom so just wondered what options there were
  2. Re: Dpf questions
    #22
    1840 Post(s)
    What you access is the engine ECU which sends and receives the signals to and from the DPF.
  3. Re: Dpf questions
    #23
    Nov 2013
    west midlands
    So there’s no way to communicate to that system with vagcom
    On Peugeot’s you can do into the actual dpf system but I know each are different
    Would a mapper have to read the map then send if it off to see or is it easy enough to see themselves
  4. Re: Dpf questions
    #24
    1840 Post(s)
    On the pug I think you mean the SCR (Selective Catalytic Reduction) system which uses a fluid like the Add-blue system on VAG cars but the BMN does not have an SCR system, part of the reason why it does not work very well. The engine ECU controls all aspects of the DPF unit.
  5. Re: Dpf questions
    #25
    Nov 2013
    west midlands
    What system does a bmm use then as it doesn’t smell at all like my old bmn
  6. Re: Dpf questions
    #26
    1840 Post(s)
    I think it is the BMN injectors as the BMM is 8 valve and uses a different design injector. On Sunday I had to venture out into Bullwell (body armour, hard hat and baseball bat required) to pick up a door lock for the front door at home. I was behind an 8P A3 quattro and I could barley breath, it stank my car out in seconds and my pollen filter is a brand new Mann Frecious Plus. When I got home and had done the door lock, I got the reg number off my dash cam and put it into my trade system, engine code BMN...
  7. Re: Dpf questions
    #27
    Nov 2013
    west midlands
    Interesting so is the bmn 16 valve then?
    Still had no dpf lights lol
  8. Re: Dpf questions
    #28
    1840 Post(s)
    Yes, like the BKD.
  9. Re: Dpf questions
    #29
    Nov 2013
    west midlands
    That’s interesting it seems to go well enough and much quicker then most bkd I’ve ever driven
  1. Considering a B6 but have a few questions
    By Dunsmorechap in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-11-2011, 08:53 PM
  2. A few questions please!
    By andirsv in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-11-2011, 09:42 AM
  3. Questions, questions, question.......
    By pitch3110 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-10-2009, 06:28 PM
  4. A Few Questions After Using Vag-Com
    By tsunami in forum VCDS - General Questions
    Last Post: 17-08-2008, 12:23 PM
  5. VR5 Questions...
    By KAPLOWW in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2008, 01:17 PM
