Thread: Dpf questions
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Dpf questions
    Nov 2013
    west midlands
    Hi all never had a vw with dpf before but picked up an 08 2.0 diesel 170bhp
    Just wondered how the regen works I seem to randomly get a charcoal kind of smell and I seem to then get white smoke
    Does it do it slowly all the time as when I got to work today it was smoking quite bad. I’ve not had any dpf lights on the dash
  2. Re: Dpf questions
    135 Post(s)
    2038 Post(s)
    The BMN engine is a nightmare, first of all you need to know if the DPF is intact internally and that the ECU software is original. After that, usually a new DPF, the first step to reducing the eye watering stench from the exhaust is to replace and carefully set up four new injectors. So, if the DPF has been rodded out and the ECU remapped to suit, rectifying the problems to a legal MOT pass (when you can get one) is more than the car is worth; hence why you picked it up cheap...
  3. Re: Dpf questions
    Nov 2013
    west midlands
    The car does seem to be original and the smell from it makes me think it’s burning off soot. The dpf light hasn’t come on yet so I have no idea if it’s intact
    Waiting for my local garage to reopen and get them to scan it see if it’s been switched off
  4. Re: Dpf questions
    135 Post(s)
    2038 Post(s)
    They stink with or without the DPF, the concept of the engine does not work, the BMN is a joke within the industry. One lady customer loved her 170 Golf but the stench it made was awful. We fitted new injectors, new DPF and the latest VAG software update at HUGE cost but eventually she gave in and bought a CR TDI Golf 7... but that runs so cold she hates it in winter. Your local a garage will not be able to see if the DPF has been rodded by a scan alone.
  5. Re: Dpf questions
    Nov 2013
    west midlands
    Thanks. I don’t mind getting my hands dirty with bits but I will just have to learn how everything operates
    You say the engine with or without dpf is an issue. Do you have a few examples and I’ll try and keep an eye on them Kinda throws out my choice of swapping for a 140bhp possibly
  6. Re: Dpf questions
    135 Post(s)
    2038 Post(s)
    There is a 140 version of this set up called the BMM but I have come across only a few although I don’t remember one stinking. I suspect the problem is the injectors used in the BMN in relation to their spray pattern and operating pressures. Personally I don’t think it is worth sinking the money into an EU4+DPF car, put it into something that won’t fall foul of the ULEZ’s although these have been pushed back a year.
  7. Re: Dpf questions
    Nov 2013
    west midlands
    That’s a shame. The car actually drives really well and only 93k i will see how it goes for a few months I will
    Always make money back onit
  8. Re: Dpf questions
    Nov 2013
    west midlands
    Does anyone know if the 08 onwards 140 bhp dpf models any good think then bmm engine code
    Reason I ask I didn’t realise then engines changed from pd to common rail. Probably why mines so quick
    I’ve got a 07 non dpf to look at but most were really slow for what they Are on test riding in the past thanks
  9. Re: Dpf questions
    135 Post(s)
    2038 Post(s)
    I have only seen a few BMM engined models but they don’t appear to be the PITA the BMN is, I am sure the BMN’s problems are down to its injectors.
  10. Re: Dpf questions
    Nov 2013
    west midlands
    Thanks for the reply I’d rather have a non dpf model but hard to get a decent one
  1. Considering a B6 but have a few questions
    By Dunsmorechap in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-11-2011, 08:53 PM
  2. A few questions please!
    By andirsv in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-11-2011, 09:42 AM
  3. Questions, questions, question.......
    By pitch3110 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-10-2009, 06:28 PM
  4. A Few Questions After Using Vag-Com
    By tsunami in forum VCDS - General Questions
    Last Post: 17-08-2008, 12:23 PM
  5. VR5 Questions...
    By KAPLOWW in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2008, 01:17 PM
