Thread: Please help with cooling fan/ fault error
  1. Please help with cooling fan/ fault error
    Aug 2012
    SOUTHAMPTON, HANTS, UK
    Hi guys,
    Can anyone say which radiator fan is fault code P1950 related to?. Mechanic failed to tell me after he scanned car and it only became an issue now, when I start looking for replacement part. Read through a lot of info on the net but still can't clearly establish if it is for left fan ( larger diameter) or right fan (smaller diameter)?
    Thank you,
    Eugene
  2. Re: Please help with cooling fan/ fault error
    Jul 2013
    76 Post(s)
    The possible fix taken from here Radiator Fan (V7) - P1950 - 008 - Movement Restricted / Jammed - Intermittent | Audi-Sport.net
    Fix : How to replace the AC air conditioning and radiator fan mk5 VW Jetta
    Start the car up with the AC off and one fan should be running then turn on the AC and the other fan should kick in, if it does not then it that one that has the issue.
    If no fan is running with the AC off then do the same and turn on the AC if the one kicks in then you that the cooling fan has the issue.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Please help with cooling fan/ fault error
    Aug 2012
    Thank you Dan,
    Checked car straight after wife came back from work so engine nice and hot.
    Results are:
    Engine ON, AC off - both fans are on Stop
    Engine ON, AC on - both fans are on Stop
    Tried to spin both with a stick, smaller fan is free spinning, bigger fan - spins but can feel certain degree of resistance, so this coupled up with a fact that larger fan houses control unit bring me to conclusion that it is a large fan that is faulty..
    Now try to find replacement unit at a decent cost.
    Eugene
  1. Cooling fan - fault?
    By hanny73 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-06-2015, 08:52 PM
  2. How To VW Polo - ABS Fault - 04FC Error Code
    By JPME in forum Polo - Derby - Lupo - Fox
    Last Post: 21-04-2011, 08:40 PM
  3. Audi a3 2004 cooling fan fault
    By sabai dee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-03-2008, 09:42 PM
  4. Fault affecting alternator, power steering and cooling system
    By valdid_shaw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2008, 01:56 PM
  5. V5 Golf Cooling Fan Fault
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-12-2006, 05:36 PM
