Thread: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #21
    1842 Post(s)
    Quote Originally Posted by the surfer View Post
    Does anyone know if I should have done a software reset after changing the high pressure fuel pump?
    No, all you have to do is bleed the system with the electric pump or pumps if it has two.
  2. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #22
    Mar 2008
    Old Wessex
    Quote Originally Posted by Roverfan View Post
    This is a long shot in the grand scheme of things but my main guess on this. Check the loom for a rub through. Follow the wiring of the pressure sensor and the regulator which are either side of the fuel rail. Follow the wiring back as far you can with a small mirror so you can see the rear of the loom at all times. You might have to get underneath the front of the car for some of this (keep safety in mind)
    I was just poking around my own car the other weak and saw my loom was out of place digging into a bracket, it reminded me of your fault
    I'll have a look at this! Thanks for the suggestion.
    Thought so - thanks!
    Looks like another trip to the garage!
    - VW Golf 1.9 GT TDI (130) - 2003
    - VW T5 Camper - 2.5 TDI - 2008
    - VW Passat Estate - 2.0 TDI - 2010
  3. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #23
    1842 Post(s)
    Don't whatever you do run or even crank over the engine before bleeding the system electrically for at least two minutes.
  4. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #24
    Mar 2008
    Old Wessex
    We done the job a couple of weeks ago and did bleed the system but probably for not as long as 2 minutes.
    Still have same problem as before.
    Going to take it back to a different garage as out of ideas now.
  5. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #25
    Mar 2022
    Kent England
    Hi - I know this is old now but just wondered if this ever came to a resolution - Your problems sound identical to the issue I now have.
  6. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #26
    1842 Post(s)
    @vheedublyou also start your own thread in the model specific forum and included a full scan with the cars VIN.
  7. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #27
    Mar 2022
    Kent England
    Hi Crasher and thanks - As its all in context I thought it better to try and speak to the original poster - It would be great anyway to see if there was a resolution to this, there is nothing worse than doing a search, reading through several pages and it goes dead at the end. I dont have a scan anyway, I have just ordered a OBD Eleven which I'm hoping will give me an insight at least on live data - My car is not producing any error codes on a regular OBD tester. My car is a 2009/2010 Tdi 140 CBA Engine Passat....Symptoms identical to this OP
  8. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #28
    1842 Post(s)
    Yes getting feedback from the other chap is good but starting your own thread as well gets more attention from other people.
  9. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #29
    Mar 2008
    Old Wessex
    Quote Originally Posted by vheedublyou View Post
    Yes I did get this resolved. Turns out that the high pressure pump was fine. Just needed a software reset with VAG Com.
    It’s been fine since then.
  10. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    #30
    Jun 2023
    Panama
    Sorry but on what you mean doing a software reset with vcds what did you do?
    Asking because i have a similar problem with my 2009 tiguan tdi
  1. BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    By gupsterg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-09-2020, 07:48 PM
  2. Erratic Idle Revs
    By Padwick in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-12-2011, 11:52 AM
  3. Question Engine Revs Fluctuating?????
    By Fattrucker in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-01-2011, 10:21 PM
  4. Idle erratic, revs dont come down quick when come to a stop!
    By enright86 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2008, 02:39 PM
  5. Fluctuating Revs on a 52 Lupo
    By Tomangela in forum Polo - Derby - Lupo - Fox
    Last Post: 10-08-2007, 09:15 PM
