Thread: Power Issues
  1. Power Issues
    Apr 2020
    Chester
    So around 2 weeks back I was doing a bit of work on my car to the radio, air suspension and fitting a sub so the ignition was on and off and had to jump start it a few times as the battery was flat due to it not being driven.
    Once I finally got the opportunity to take it for a nice drive, it was fine for a week.
    Yesterday, started it up in the morning - was fine. Left it running for 10 minutes and turned it off. In the evening I went out and it wouldn't unlock with the key, I had to put the key in the door to unlock, there was no interior light, no ignition or power to start the car.
    Jump started it this morning, it took a while but it eventually started. It started up and ran fine in the end, everything seemed to work like it should have. However, when i revved the car up the lights and speedo cut out for a second then come back on with a few beeps. The battery light would come on and red steering light.
    Plugged it into Carista and these are the codes I am getting:
    00668 - Supply Voltage Terminal 30
    00532 - Supply Voltage B+
    Then I am getting (which I assume are all releated)
    01812 - Supply Voltage for Door Cotroller pass. side J387
    01813 - Supply voltage for door controlle rear left J388
    01814 - Supply voltage for door controller rear right J388
    00446 - Function limitation due to under voltage
    00447 - Function limitation due to voltage to high
    It's a 1.9tdi
    Any ideas where to start?
  2. Re: Power Issues
    Mar 2018
    GB
    19 Post(s)
    A working battery would be a good place to start.
    Sent from my SM-G950F using Tapatalk
  3. Re: Power Issues
    Apr 2020
    Chester
    Quote Originally Posted by bill.wj.wilson View Post
    New battery in... It starts fine. Runs for 3 seconds and all interior electrics (including speedo, wipers, windows etc) all cut out.
  4. Re: Power Issues
    Mar 2018
    GB
    19 Post(s)
    Check earthing points, relays for corrosion, something is overheating and causing a shutdown, electrical issues can be a bitch to trace, but it sounds like something is loose or corroded, its a process of elimination.
  1. power tailgate issues
    By quattrogary in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-08-2017, 01:30 PM
  2. A3 BFQ Engine power issues at low RPM
    By AirBoy in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-02-2015, 10:26 PM
  3. Power steering issues
    By vegvan in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-08-2009, 09:22 PM
  4. Please Help Power issues with 1.8T
    By MikeyM2005 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2008, 07:45 PM
  5. VW TDi 2.5 Transporter power issues
    By Discover in forum The Commercial Range
    Last Post: 14-05-2008, 07:10 PM
