Thread: Golf MK5 2.0 TDi Plus not starting - Would faulty brake lights switch be cause?
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Golf MK5 2.0 TDi Plus not starting - Would faulty brake lights switch be cause?
    1836 Post(s)
    Quote Originally Posted by mickeybo View Post
    why was my other post blocked
    I can’t see anything wrong?
  2. Re: Golf MK5 2.0 TDi Plus not starting - Would faulty brake lights switch be cause?
    Nov 2016
    Ireland
    14 Post(s)
    If the car is a BKD I can give you pics of the fuse box layouts in my car if ye think they should be the same, mines a normal golf BKD 2008.
  3. Re: Golf MK5 2.0 TDi Plus not starting - Would faulty brake lights switch be cause?
    1836 Post(s)
    The Golf and Golf Plus use different fuse box and control systems, the Golf is in the dash side and the Plus is under the dash above your legs, the same as the Caddy and the Touran. Why VW did this I have no idea, there must be a good reason... you would think!
  4. Re: Golf MK5 2.0 TDi Plus not starting - Would faulty brake lights switch be cause?
    Aug 2020
    Bridgend
    Sorry if I'm hijacking your thread. I'm new here and a green DIY'r , my question is. Are the fuse boxes in the BKD engine for a Golf mk5 GTTDI 2.0 2005 the same in every mk5 GTTDI 2.O 2005?
  1. Rear Lights Not Working - Faulty Boot Sill Switch
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 14-06-2018, 08:16 AM
  2. Faulty brake light switch, does it cause.....
    By AliBailey88 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2011, 07:25 PM
  3. Please Help Vascom reports faulty Brake light switch, But...
    By OpenRoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-03-2010, 07:54 PM
  4. Help with faulty brake lights
    By Nanashi1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-08-2007, 01:53 PM
  5. HELP! - faulty brake/indicator lights, golf gt tdi, 1998
    By gtisamantha in forum Archive posts
    Last Post: 24-07-2006, 02:45 PM
