Thread: 2008 Passat 1.9 TDi Estate just died - twice
  1. 2008 Passat 1.9 TDi Estate just died - twice
    Nov 2018
    Tamworth
    22 Post(s)
    Hi all,
    A bit of a problem .
    Car has just completely died at some traffic lights. No warning, no warning lights, just stopped running.
    Disconnected the battery, left for a minute or so, reconnected and she fired up.
    A mile later on while parking she did exactly the same thing again. Battery disconnected again and managed to get her parked up.
    Battery disconnected voltage 12.8V
    Battery voltage with engine running 14.2V
    Warning lights now on: Steering & Traction Control
    Fuel filter last changed Nov 2015 @ 106K
    VDCS logs:
    When parked up:
    Code:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN:****   Mileage: 225490km-140112miles
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Sporadic communication error 1000
    72-Door, Rear Right -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
       Component: R4 1,9L EDC G000SG  9248
       Revision: --H08---    Serial number: VWZCZ000000000
       Coding: 0000071
       Shop #: WSC 05311 000 00000
       VCID: 7AAC04FBC0D72B5B1DF-802E
    1 Fault Found:
    005659 - Glowplug for Cylinder 2 (Q11)
                   P161B - 000 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00110000
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 224785 km
                        Time Indication: 0
                        Date: 2020.03.21
                        Time: 16:20:05
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 12.24 V
                        Bin. Bits: 00101000
                        Temperature: 19.8°C
                        Bin. Bits: 00110000
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
       Component: J104    C4 440 V2   0003
       Revision: --020---    Serial number: 00000785271408
       Coding: 0001282
       VCID: 1F1A156F3BB5AE734A1-804A
    2 Faults Found:
    00576 - Terminal 15
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 36
                        Mileage: 225498 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 13:13:10
                 Freeze Frame:
                        Speed: 12.0 km/h
                        Hex Value: 0x000B
                        Voltage: 13.00 V
                        Bin. Bits: 00111110
                        Count: 123
    00778 - Steering Angle Sensor (G85)
                005 - No or Incorrect Basic Setting / Adaptation
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 36
                        Mileage: 225498 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 13:13:10
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 77AA1DCFF3C53633621-8022
    3 Faults Found:
    00819 - High Pressure Sensor (G65)
                009 - Open or Short to Ground - Intermittent
    01316 - ABS Control Module
    01314 - Engine Control Module
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Component: Bordnetz-SG     H54 2202
       Revision: 00H54000    Serial number: 01000008124400
       Coding: 00888F0700041A00470A00000F000000000859435C000100000000000000
       Shop #: WSC 05124 000 00000
       VCID: 71BE23D79DA16803AC5-8024
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 130208 022  0601
       Coding: 00046997
       Shop #: WSC 05124
    5 Faults Found:
    02395 - Parking Light Front Right (M3)
                012 - Electrical Fault in Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 64
                        Mileage: 225249 km
                        Time Indication: 0
                        Date: 2020.03.30
                        Time: 14:52:00
                 Freeze Frame:
                            ON
                        Voltage: 11.60 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01499 - Bulb for High-Beams; Right (M32)
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00101010
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 64
                        Mileage: 225249 km
                        Time Indication: 0
                        Date: 2020.03.30
                        Time: 15:26:00
                 Freeze Frame:
                            ON
                        Voltage: 11.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00979 - Lamp for Low Beam; Right (M31)
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 64
                        Mileage: 225249 km
                        Time Indication: 0
                        Date: 2020.03.30
                        Time: 15:26:00
                 Freeze Frame:
                            ON
                        Voltage: 11.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01333 - Door Control Module; Rear Left (J388)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 54
                        Mileage: 224341 km
                        Time Indication: 0
                        Date: 2020.03.16
                        Time: 10:40:00
                 Freeze Frame:
                            OFF
                        Voltage: 12.50 V
                            OFF
                            OFF
                            OFF
                            OFF
                            OFF
    01334 - Door Control Module; Rear Right (J389)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 54
                        Mileage: 224341 km
                        Time Indication: 0
                        Date: 2020.03.16
                        Time: 10:40:00
                 Freeze Frame:
                            OFF
                        Voltage: 12.50 V
                            OFF
                            OFF
                            OFF
                            OFF
                            OFF
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__006 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DP3H2YYB
       Coding: 0012342
       VCID: 3B22C1FF8F6DD253469-806E
       Subsystem 1 - Serial number: 6333FTS670910318
       Subsystem 2 - Serial number: 6343FTS640020258
       Subsystem 3 - Serial number: 6353ETS6RODISVNP
       Subsystem 4 - Serial number: 6363ETS63RIHSVNH
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    No fault code found.
    Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
       Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C9953507AT
       Coding: 0000112
       VCID: 6FBA25AF8B957EF3BA1-803A
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           002 0010
    1 Fault Found:
    Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
       Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 00657 067 57207
       VCID: 270A0D8F63E566B3321-8072
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P0822301F1
       Coding: F9807F060002022003
       VCID: 2312199F17DD8A936E9-8076
    4 Faults Found:
    01305 - Databus for Infotainment
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 1
                        Fault Frequency: 2
                        Reset counter: 142
                        Mileage: 213423 km
                        Time Indication: 0
                        Date: 2019.09.10
                        Time: 11:05:45
    01304 - Radio
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 142
                        Mileage: 213423 km
                        Time Indication: 0
                        Date: 2019.09.10
                        Time: 11:05:50
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 54
                        Mileage: 224341 km
                        Time Indication: 0
                        Date: 2020.03.16
                        Time: 10:40:50
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 54
                        Mileage: 224341 km
                        Time Indication: 0
                        Date: 2020.03.16
                        Time: 10:40:50
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 392EDBF78551E043545-806C
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    1 Fault Found:
    02828 - Enabling Steering Column Lock from Diagnostic Interface
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 2
                        Reset counter: 76
                        Mileage: 225498 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 13:13:18
    Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
       Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
       Component: J386  TUER-SG FT    1132
       Revision: 32008001    Serial number: 00000115788224
       Coding: 0000693
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
                 Freeze Frame:
                        Fault Status: 01100101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 36
                        Mileage: 0 km
                        Time Indication: 0
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.134 H08 1901
       Shop #: WSC 02069 000 90108
       VCID: 3634D0CBB44F0F3BB97-8062
    1 Fault Found:
                000 - -
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 042 0472
       Coding: 0191020051030E763004941570085FCE107C01
       Subsystem 1 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H08 9001
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1132
       Revision: 32008001    Serial number: 00000527688216
       Coding: 0000692
       VCID: 3C20C2E38A63D56B4F3-8068
    2 Faults Found:
    00933 - Electric Window Motor; Passenger Side (V148)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 36
                        Mileage: 0 km
                        Time Indication: 0
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 74
                        Mileage: 225425 km
                        Time Indication: 0
                        Date: 2020.04.22
                        Time: 08:44:18
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
       Component: J540 EPB3  VW-09393 0009
       Revision:   008       Serial number: 00000000370173
       Coding: 0000057
       VCID: 290E0BB775F150C3245-807C
    3 Faults Found:
    00576 - Terminal 15
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 36
                        Mileage: 225498 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 13:13:08
                 Freeze Frame:
                        Voltage: 13.50 V
                        Count: 54
                        Speed: 16.0 km/h
                        Hex Value: 0x1260
                        Hex Value: 0x0004
                        Hex Value: 0x0101
    01321 - Control Module for Airbags (J234)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 76
                        Mileage: 225498 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 13:13:08
                 Freeze Frame:
                        Voltage: 13.90 V
                        Count: 76
                        Speed: 16.0 km/h
                        Hex Value: 0x1270
                        Hex Value: 0x0004
                        Hex Value: 0x0101
    02844 - Lamp for Automatic Parking Function
                 Freeze Frame:
                        Fault Status: 00101001
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 76
                        Mileage: 225498 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 13:13:08
                 Freeze Frame:
                        Voltage: 13.70 V
                        Count: 83
                        Speed: 16.0 km/h
                        Hex Value: 0x1270
                        Hex Value: 0x0004
                        Hex Value: 0x0101
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000235473
       Coding: 0000144
       VCID: 70B826D396AB610BA3B-8024
    Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000243339
       Coding: 0000144
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.6V/12.5V)-----------
    Log after clearing the DTC's and re-starting:
    VIN: ****  Mileage: 225490km-140112miles
    01-Engine -- Status: OK 0000
       Coding: 0000071
    Readiness: 0 0 0 0 1
       Coding: 0001282
    1 Fault Found:
       Coding: 00046997
       Shop #: WSC 05124
       Coding: 0012342
       Coding: 0000112
       Coding: 0007405
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 36
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:37:37
    01304 - Radio
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 36
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:37:42
       Coding: 0000693
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 36
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:37:37
    1 Fault Found:
                000 - -
       Coding: 0000692
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 36
                        Mileage: 225499 km
                        Time Indication: 0
                        Date: 2020.04.26
                        Time: 01:37:37
       Coding: 0000057
    Address 56: Radio
    Cannot be reached
       Coding: 0000144
       Coding: 0000144
    End----(Elapsed Time: 01:34, VBatt start/end: 12.7V/12.4V. VIgn 0.0V)------
    She's got an aftermarket radio without the CAN adapter so that's why this can't connect.
    There's no engine fault codes. Erm......
    From the Ross Tech site Code 0778 gives:
    00778 - Steering Angle Sensor (G85): No or Incorrect Basic Setting / Adaptation
    Possible Causes
    • Steering Angle Sensor (G85) Basic Setting lost
    Possible Solutions
    • Perform Steering Angle Sensor (G85) Basic Setting
    Special Notes
    • When this DTC will not clear in Mk70 and MK60 ESP equipped (1K) Golf models see the WSS (Wheel Speed Sensor) notes Here.
    I can't see how the steering stuff would make the car stop running. Or am i missing something?
    Unfortunately I don't understand what I need to do next with the Steering Angle or if this is actually what caused the car to stop running or is a result of it, not the cause.
    I was wondering if it was something to do with tickover as both "dying" episodes happened on tickover??
    Do I need to delve further into VDCS diagnostics? Or something else?
    Help and suggestions gratefully received.
    Andy.
  2. Re: 2008 Passat 1.9 TDi Estate just died - twice
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I think most of your faults have been brought on by disconnecting the battery.
    You need to restore basic settings for steering, which should just need a drive giving it full lock in both directions.
    Otherwise follow the Ross-Tech procedure.
    Your original problem could be an intermittent in-tank fuel pump.
    When it fails again try giving the tank a good thump, then listen for the pump running for a couple of seconds when the ignition is turned on.
  3. Re: 2008 Passat 1.9 TDi Estate just died - twice
    Nov 2018
    Tamworth
    22 Post(s)
    Thanks.
    It was all a bit odd as after she stopped the key did nothing. I took it out completely, tried again, still nothing. Did that a couple more times, still absolutely dead. No sounds, no "trying" to start, nothing. Have to admit I didn't listen for the pump
    Disconnected the battery and at least she fired up.
    Hope it's not the fuel pump as I gather they are pretty expensive and not a joy to fit.
    Andy.
  4. Re: 2008 Passat 1.9 TDi Estate just died - twice
    1836 Post(s)
    The steering sensor is because you disconnected the battery, a couple of lock and hold lock to locks and a quick drive normally shuts it up. How old is the battery? I am finding the 2006>2010 3C to be extraordinarily fussy about the battery, our 2010 loan car does all sorts of odd things if the battery voltage drops too low from short trip work... in fact it is completely dead somewhere at the moment, the person who had it broke it and I haven't got time to go fetch.
  5. Re: 2008 Passat 1.9 TDi Estate just died - twice
    Nov 2018
    Tamworth
    22 Post(s)
    Thanks Crasher.
    She went on a shopping trip last night and everything worked fine. All the warning lights have gone including the steering one. I'll run a scan in the next couple of days when it stops raining for 10 minutes.
    I don't know about the battery as it's the one I bought her with. I'll keep a close eye on it and I've a spare, fully charged, 096 so I might swap them over to see if that makes any difference.
    Andy.
  6. Re: 2008 Passat 1.9 TDi Estate just died - twice
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by AndyN01 View Post
    Thanks Crasher.
    Andy.
    I change the fuel filter at the same time I do my 9500 mile oil service as they are only around a tenner these days, less as I get a few at a time when on offer. 34,000 since a fuel filter change is quite a gap, for me at least. I'd change the fuel filter too but at 140k+ I'd join philipharmes with the in tank fuel pump theory as a lot give in during the 2nd 100k of the car's life. Failure of this pump can be preceded with intermittent cut outs and non starts until it finally won't run anymore. Fairly easy change and around £75 to silly money for a new unit. There are a couple of different types (2 port, 3 port) so it is important to get the right replacement.
  1. BKP Passat just died
    By Jonty3962 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-03-2016, 01:38 PM
  2. A6 Avant 2.7tdi 2008 manual 66k miles - engine died and will not start
    By gringosmith in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-05-2015, 08:24 PM
  3. 2008 Passat Estate Tailgate exterior trim
    By noletastic in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-05-2014, 04:16 PM
  4. 2008 Passat B6 Estate DAB Aerial location
    By coatsy35 in forum In Car Entertainment
    Last Post: 21-12-2013, 06:05 PM
  5. 2008 Passat Estate - roof bars & box wanted/advice
    By princebishop75 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 18-02-2010, 03:56 PM
