Thread: check coolant level message
  1. check coolant level message
    Jul 2015
    GB
    My 2015 B8 75k miles, reports a message saying check coolant when started from warm, never from cold. The coolant level is fine temp gauge is fine.
    The VW dealer said it was the water pump which has been replaced by them but the message still appears.
    Does anyone have any ideas what it may be?
  2. Re: check coolant level message
    Jan 2016
    Winchester Hants
    29 Post(s)
    The only time I have had 'check coolant' was with an Audi A4 at any time, cold or warm. The plastic header tank was always full when I checked. Replacing the header tank cured the issue. It must have been the sensor inside the tank.
    Perhaps try cleaning the contacts to the plug in connector...if it has one.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  3. Re: check coolant level message
    Jul 2015
    GB
    Quote Originally Posted by UMEL View Post
    The dealership claim to have checked all the obvious like sensors etc. It's odd because the message only happens when the engine has done a long run.
  4. Re: check coolant level message
    Jan 2016
    Winchester Hants
    29 Post(s)
    Service engineers have been known to be wrong. There's a float type sensor in the expansion tank (remembered the correct name) which makes and breaks. It was the float or contact therein that was faulty in mine. You could remove the plug and short out the two terminals then run it to see if the warning appears
  5. Re: check coolant level message
    Jul 2015
    GB
    I couldn’t get the connector off to look. Any suggestions?
  6. Re: check coolant level message
    Feb 2020
    Bradford
    40 Post(s)
    Quote Originally Posted by ian.roger.smart View Post
    They are usually stuck on if not removed for a few years. Press the two connectors further together as much as you can (this will lessen friction of where they latch together)
    Then press down on the tab. Pressing on the tab lifts the other side where it engages the male connector, its like a seesaw. They can be fragile so carefully considered force should be applied
    Google Image Result for https://www.a2oc.net/community/index.php?attachments/picture032-jpg-original-jpg.36006/
  1. STOP! Check Coolant warning message - Mk4 Diesel Golf
    By utilityplayer in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2021, 10:36 AM
  2. Question Coolant level message but coolant is ok
    By Akash in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-07-2017, 12:08 AM
  3. Check Coolant Water Level
    By popin in forum Golf MK4 - 1999 - 2004
    Last Post: 09-08-2011, 08:14 AM
  4. oil level check message
    By cueboydave in forum Touareg
    Last Post: 24-01-2010, 03:35 PM
  5. stop check coolant level
    By robert310383 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-07-2008, 06:18 PM
