Thread: OBD11 Code U111100 Function Limitation due to Missing Message
  1. OBD11 Code U111100 Function Limitation due to Missing Message
    Jun 2018
    Dubai. UAE
    I've looked everywhere but cannot find any info on this code.
    It's under the Brakes module. I've had it for over a year and there's no way to reset it.
    Anybody knows what it means and/or how to reset it?
    TIA
    AUDI A7 2013 3.0 TFSI
    Sent from my HD1913 using Tapatalk
  2. Re: OBD11 Code U111100 Function Limitation due to Missing Message
    1836 Post(s)
    The battery is seven years old, it would make sense to start with a new one.
  3. Re: OBD11 Code U111100 Function Limitation due to Missing Message
    Jun 2018
    Dubai. UAE
    Hi.
    Thanks for your reply. Maybe at the time of first ocurrence last year, that might have been the reason. However, battery has been replaced with a new one and I'm still unable to reset the message.
  4. Re: OBD11 Code U111100 Function Limitation due to Missing Message
    1836 Post(s)
    The next step would be to put it on the VAG diagnostic system ODIS and run Guided Fault Finding to see what it suggests.
  1. Missing PR Code Sticker?
    By Boat_face in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-09-2016, 06:24 PM
  2. Replies: 17
    Last Post: 24-03-2015, 06:08 PM
  3. code for Multi function steering buttons
    By manity in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-09-2011, 08:42 PM
  4. Replies: 6
    Last Post: 01-07-2008, 01:31 PM
  5. Passat fault Code: 18034 Powertrain data bus: Missing message from tcu
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 12:00 PM
