Thread: Steering fault
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: Steering fault
    #21
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Faults refer back to the wiring issue with the earth missing hence no power.
    Your module is fine just need the wiring sorting out
    Angle sensor fault should disappear once power is restored otherwise its easy enough to recalibrate the angle sensor
  2. Re: Steering fault
    #22
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    Quote Originally Posted by morski View Post
    Weird thing is the car is now working normally and that earth wire is not plugged in.......has to be an intermittent connection somewhere in the loom......
    I’ve left the codes in the system and sent them to my mechanic; hopefully he will get back to me in the morning and get it booked in for a permanent fix
  3. Re: Steering fault
    #23
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    Car went back to the garage today for further investigation.........couldn’t find anything obvious Checked through the wiring and everything passed his tests
    The only thing i can now think of is water ingress into the wiring. What i hadn’t previously mentioned is that when the fault first occurred back in November last year we had had some heavy rain and i had to navigate several deep puddles to get home.....this time i had recently jet washed the engine bay (done it loads of times previously!)
    i can only assume water has ingressed and caused an electrical hissy fit......my gearbox undertray has been missing since I owned the car so I’ve now sourced a replacement as that will cover the steering rack and hopefully help reduce the chances of this happening again. Suffice to say I won’t be jet washing the engine bay any time soon......!!!
    Time will tell if I’ve dodged a bullet on this issue!
  4. Re: Steering fault
    #24
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    Time did indeed tell......
    Fault has reappeared.......
    This time i can 100% guarantee that water was not present! I’m starting to think something in the rack is breaking down
  5. Re: Steering fault
    #25
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    I suggest you start by replacing the wiring loom for the rack as whether you replace the rack inthe future this will still need changing.
  6. Re: Steering fault
    #26
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    Will try and get it booked in again although currently the fault has disappeared again........when i scanned for fault codes only the steering angle sensor fault was present; no other voltage codes this time
  1. Steering gear fault. Steering rack box knocking noise
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-08-2020, 06:46 AM
  2. Question Steering fault
    By terry.hatton in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-04-2019, 01:12 PM
  3. Replies: 4
    Last Post: 08-03-2018, 01:41 PM
  4. Steering lock fault : system fault! contact workshop.
    By DJS11 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-12-2017, 11:20 PM
  5. FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    By rogerholmesuk in forum Golf MK5 - 2004 - 2009
    Last Post: 11-05-2011, 09:03 PM
