Thread: 1.9tdi (BRS) EGR valve fault?
  1. 1.9tdi (BRS) EGR valve fault?
    Apr 2020
    Peterborough
    First time posting but after plenty of reading around.
    My VW T5 2008 with a 1.9tdi engine (BRS) has been feeling underpowered and becomes choked on acceleration, particularly as the you come to the end of accelerating just before you would change gear. Here the engine ‘surges’ with black smoke, presumably as the combustion becomes incomplete.
    After testing and checking the following, I have found the EGR seems to be the problem. For now I’ve unplugged it and the engine now runs smooth, but I would like to be sure it’s the EGR before I replace it.
    Checked/tested and OK;
    -MAF sensor (electrics and sensor ok)
    -Vacuum hoses (manually pulled a vacuum and it holds, pressure on main line at 20mmHG)
    -turbo hoses not leaking, good seals
    -EGR electrics as spec
    -N75 solenoid recently replaced (previous ‘moo’ issue
    -Air Intake Manifold, Throttle body and EGR valve all cleaned. EGR valve mechanism not obviously damaged and appears to close fully. I don’t have an EGR actuator year tool or VCDS to test the full operation of it.
    Engine has only done 70k in its lifetime.
    Any advice would be much appreciated so I can rule everything else out before I replace the EGR valve.
  2. Re: 1.9tdi (BRS) EGR valve fault?
    1837 Post(s)
    You should see how blocked the entire system gets
  3. Re: 1.9tdi (BRS) EGR valve fault?
    Apr 2020
    Peterborough
    Yes I’ve had that all off and cleaned. Wasn’t quite as bad as yours there though. I had hoped that would sort things. It’s almost like the EGR solenoid is being told to, or is opening too much on its own.
    looks like I only have a pic of the EGR (before I cleaned it)
  4. Re: 1.9tdi (BRS) EGR valve fault?
    1837 Post(s)
    That one is a customers van and in the last three years we have done that twice. To reduce labour costs an guarantee success we fit a new flap motor and EGR valve whilst the cooler and manifold go in the dip overnight.
  5. Re: 1.9tdi (BRS) EGR valve fault?
    Apr 2020
    Peterborough
    Found the problem this eve, so sharing for anyone else who might have the same problem.
    To cut a long story short, the vacuum/brake booster hose did not have a good seal at the connection to the tandem pump.
    Last week I took the EGR off for the second time in three months, bench tested and realised the valve wasn’t opening fully. I missed that last time and thought the action it had last time was the full motion. Took it apart, cleaned and oiled, bench tested to check and put it back on. Noticeably better performance of the engine and exhaust smells reduced but performance was still not right. I realised the choking & black smoke when accelerating sometimes must be because of something else. Back to the vacuum.
    Decided this eve to test the vacuum system again. First test, struggled to get 25mmHg and noticed all was lost quickly when moving the vacuum hose connection at the tandem pump.
    Video of vacuum test: 9 May 2020 - YouTube
    Ran a second test to see if I could pull a full vacuum directly on the vacuum pump to check the leak was definitely at the connector - it was.
    New assembly just purchased for £60 shipped from Germany.
  6. Re: 1.9tdi (BRS) EGR valve fault?
    May 2012
    Everywhere
    308 Post(s)
    The Devil valve...
  7. Re: 1.9tdi (BRS) EGR valve fault?
    Apr 2020
    Peterborough
    No doubt it will be clogged again in a few thousand miles. But at least my vacuum issue will now be sorted. It’s been holding the turbo back and loosing pressure causing the engine to choke itself on acceleration sometimes, but always with a long groaning moo after.
  1. MK4 golf 1.9tdi egr valve.
    By ScottVKG in forum Golf MK4 - 1999 - 2004
    Last Post: 20-03-2018, 04:45 PM
  2. Please Help Need information on Fault code relating to EGR valve possible fault from emissions fix.
    By danet88 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-03-2017, 07:44 PM
  3. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  4. Replies: 0
    Last Post: 03-12-2013, 11:51 PM
  5. dump valve a3 1.9tdi
    By brickyman1984 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-06-2010, 08:18 PM
