Thread: Fan problem or not?
  1. Fan problem or not?
    Apr 2020
    Alvechurch
    newbie question,
    I have a 2015 2.0TDI, the radiator cooling fans seem to be running (at speed) virtually every time I get out the car!
    The car seems to be running fine, coolant level is good, however the fact the fans are running like they do when the engine is cold just doesn't seem right to me!
    Thoughts anyone....
    Thanks in advance..
  2. Re: Fan problem or not?
    Apr 2009
    It's normal
    Sent from my MI 6 using Tapatalk
    Audi A4 Avant 2.0 TDi 2009
  3. Re: Fan problem or not?
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    It sounds like the engine is trying to regenerate the Diesel Particle Filter after lots of short runs.
    It is normal, but it would be better if you took the car for a longer run, probably at least 10 miles.
    That should allow it to complete a regen & all should be good again.
  4. Re: Fan problem or not?
    Apr 2020
    Alvechurch
    Quote Originally Posted by philipharmes View Post
    Thanks for the info.
    Only being doing short journey's during this lockdown period, local shop and back. My normal journey to work is circa 30 miles each way, 75% of which is on the motorway, so at speed. Would the DPF clog up this quickly?
    Thanks..
  5. Re: Fan problem or not?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Quote Originally Posted by Tood W View Post
    Thanks..
    Doing very short journeys can be problematic for DPF equipped engines.
    My daughter has a (Please no Swearing) Peugeot 308 2.0ltr diesel and this suffered the same in recent weeks, I have just been for a 25>30 mile run, using one gear lower than normal (using 5th gear instead of 6th) to help increase engine RPM DPF regen completed OK and fans now run as normal.
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Replies: 19
    Last Post: 24-12-2011, 09:45 PM
  3. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
