Thread: 2.4 V6 auto transmission pipes
Results 1 to 10 of 11
  1. 2.4 V6 auto transmission pipes
    Feb 2020
    Rugeley Uk
    Hi has anyone got a photo from underneath of these please. I've a leak and need to see where it's coming from thanks
    Sent from my VTR-L09 using Tapatalk
  2. Re: 2.4 V6 auto transmission pipes
    1836 Post(s)
    I can do a parts diagram but I would need you to private message me the reg before I go home.
  3. Re: 2.4 V6 auto transmission pipes
    Feb 2020
    Rugeley Uk
    Hi. Thanks. Just sent you it
  4. Re: 2.4 V6 auto transmission pipes
    1836 Post(s)
    There are two different systems, I think yours is the upper as the car is too early for the system to show which ones are correct.
  5. Re: 2.4 V6 auto transmission pipes
    Feb 2020
    Rugeley Uk
    It's wet around there which is close to the exhaust. I can't see where the rest of the pipe work goes
  6. Re: 2.4 V6 auto transmission pipes
    1836 Post(s)
    At the two coupling points? You need to get it on a lift.
  7. Re: 2.4 V6 auto transmission pipes
    Feb 2020
    Rugeley Uk
    I've tightened the joints up a touch and put self amalgamating tape around them. I'll go for a drive and see if it still leaks later.
  8. Re: 2.4 V6 auto transmission pipes
    1836 Post(s)
    1 1 0
  9. Re: 2.4 V6 auto transmission pipes
    Feb 2020
    Rugeley Uk
    It's wet around no13. Even if on ramps there's no way of getting to the pipe work above the gearbox
  10. Re: 2.4 V6 auto transmission pipes
    1836 Post(s)
    You have to tilt the box down, engine up.
  1. Question What Pipes/cooler A4 3.0 TDI Quattro auto 2005
    By fifer99 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-10-2017, 05:04 PM
  2. auto transmission help please
    By deutsch in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2012, 09:23 PM
  3. Auto transmission fault
    By yorky19640 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2011, 03:52 PM
  4. auto transmission woes
    By saxon10sept in forum Golf MK3 - 1993 - 1999
    Last Post: 19-06-2010, 06:54 PM
  5. Touareg auto transmission
    By edwinge in forum Touareg
    Last Post: 08-09-2007, 11:57 PM
