Thread: 2.0 TDI engine issue BPW
  1. 2.0 TDI engine issue BPW
    Feb 2020
    spalding
    Thoughts on this issue 2009 Audi 2.0 tdi BPW engine
    Recently changed the turbo all went well till I started the car flashed up straight away after a couple of minutes gave it a little rpm 3k and the low pressure oil flashed on for about 3 secs just after the engine just stopped. Tried to restart it and it just turned over 3 or 4 times and stopped. Engine wasnt hot as only been running a couple of minutes. New battery still the same turns a couple of times slowly then stops.
    Have now taken front of car put a bar on the crankshaft and although was initially tight is now freely moving and you can feel each piston coming to tdc.
    Any ideas and possible way forward is the engine scrap or have I missed a bullet and something just needs replacing
  2. Re: 2.0 TDI engine issue BPW
    1837 Post(s)
    I think you have oil pump drive failure there, random, common and nothing to do with what you have done; it’s a scenario every garage fears.
  3. Re: 2.0 TDI engine issue BPW
    May 2012
    Everywhere
    308 Post(s)
    I lost count years ago .
    BPW , double trouble 77mm and chain driven .
  4. Re: 2.0 TDI engine issue BPW
    1837 Post(s)
    Being a 2008 (it can’t be an 8E and be a 2009 model) it is at least gear driven but does have that incredibly stupid reversion back to a 77mm hex, I cannot comprehend why they went 77, 100, 77 and back to 100; whichever ***** of a bean counter was responsible for that decision should not be in a position of responsibility.
  5. Re: 2.0 TDI engine issue BPW
    May 2012
    Everywhere
    308 Post(s)
    They had loads of 77mm modules left and thought , "Oh well.."
    He's very certain on BPW which is a PD , a late registered B7 or just B8 but confused on engine code which should be CR ?
  6. Re: 2.0 TDI engine issue BPW
    1837 Post(s)
    The BPW ran through to the end of 8E production in theory but received the 100mm shaft at late 2006.
  7. Re: 2.0 TDI engine issue BPW
    May 2012
    Everywhere
    308 Post(s)
    Some , the utter madness of it .
  1. 5v engine issue
    By nobbybonez in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-10-2013, 04:47 PM
  2. 2.7 tdi engine issue?
    By irasko1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-09-2011, 10:06 AM
  3. Important Engine Issue! Help!
    By nizzex in forum Golf MK4 - 1999 - 2004
    Last Post: 12-06-2010, 07:03 PM
  4. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  5. Please Help engine issue- 2 of them!
    By kennynj in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2008, 06:04 PM
