Thread: Air con issue
  1. Air con issue
    Ireland
    Turning it to minimum yesterday I wasn’t happy with the temperature...it wasn’t cold enough. Felt more like 19 or 20 degrees. Is this likely to be low freon levels? Ta
  2. Re: Air con issue
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I`m not sure what effect this feature has, but do you have settings in your MMI for Aircon? There are 3 on mine, try turning to maximum if you have and try. If you have it on high, get a code scan for any related faults.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Air con issue
    1840 Post(s)
    The system is self monitoring so if the pressure is low it will generate a code and low pressure is usually the sender itself leaking however failure of the compressor is becoming very common is is quite on these modern constant drive compressor, hard to diagnose so we use the method of no codes, no chill, new compressor. Systems running the new R1234yf refrigerant seem particularly prone to compressor failure.
  1. Issue with 2019 Q7 50 TDi - Hesitation from speed sensor issue
    By marcusjames in forum Q7 - 4M Forum - 2016 -
    Last Post: 07-02-2020, 06:01 PM
  2. Another Key Issue
    By naz5 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-01-2014, 08:17 PM
  3. a6 oil sensor issue and airbag issue
    By 2400 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-12-2012, 11:26 AM
  4. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  5. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
