Thread: 2009 2.0TDI Sportline Rear Suspension
  1. 2009 2.0TDI Sportline Rear Suspension
    Apr 2020
    Salfords, Surrey
    Hi everyone,
    New to the forum but looks to be a good depth of knowledge on here!
    I've just bought a 2009 Golf Sportline estate which eventually I want to use as my work car; I'm an industrial steam boiler engineer so heavyish tools.
    The rear suspension is mega soft and has dropped a fair amount causing the wheels to not sit straight so I want to replace it. My question is simple but just want to make sure. As it's the Sportline model I'm assuming it's fitted with the sport suspension such as this sold on Euro Car Parts?
    Coils:
    Sachs Coil Spring | Euro Car Parts
    Shocks:
    Sachs Shock Absorber | Euro Car Parts
    Or as I'll be carrying a boot full of tools is it better to fit heavy duty springs and if so where can I buy these please?
    On the other hand I've read good things about Koni Special-Active shocks, look to just be an OEM direct replacement, will these fit a car with the "sport" suspension? Has anyone got experience with these?
    Koni Special-Active Rear Shock Absorber for VW - larkspeed.com
    Sent from my Pixel 4 XL using Tapatalk
  2. Re: 2009 2.0TDI Sportline Rear Suspension
    1840 Post(s)
    Could you private message me your reg number so I can check the pr codes?
  3. Re: 2009 2.0TDI Sportline Rear Suspension
    1840 Post(s)
    It has the 1JC rear sports suspensions uses the specific rear springs 1K0 511 115 BT and dampers plus shortened 118mm rear bump stops so the rear springs cross reference correctly but the rest of it is unclear as the internet seems to have Covid and is being unreliable.
  4. Re: 2009 2.0TDI Sportline Rear Suspension
    Apr 2020
    Salfords, Surrey
    Ha ha, thanks for the info. So I'd assume if those springs from Euro Car Parts match up then the shocks will as well appreciate the help!
    After hearing an ominous noise today it's looking like I might need to change the DMF and clutch as well ! Only bought the car a month ago, bad times!
  5. Re: 2009 2.0TDI Sportline Rear Suspension
    May 2020
    Kingswinford England
    Hi, I'm in the same boat, as I had a broken spring spotted at the MoT station. VW Customer Service says that they have access to part numbers, but can't/won't give them to me; I'm supposed to have it looked at by one of their dealers, before they will tell me! What sort of customer service is that?
  6. Re: 2009 2.0TDI Sportline Rear Suspension
    Apr 2020
    Salfords, Surrey
    That's terrible. I bought the parts from ******* along with clutch and flywheel and I'm going to do it all myself. Crasher on here was very helpful and could tell me what part numbers I needed for my springs
  7. Re: 2009 2.0TDI Sportline Rear Suspension
    1840 Post(s)
    Although take great care with *******, they lie and don’t have any in depth knowledge about what they are doing; you have to know exactly what you want and not trust their intervention via VIN as it is not accurate.
  8. Re: 2009 2.0TDI Sportline Rear Suspension
    Apr 2020
    Salfords, Surrey
    Ah, wish I'd known that. I had the car off the ground last weekend and the springs are correct (although to did give me the OEN for those), shocks looked correct too but I forgot to order the dust covers so just waiting on those, hopefully should be all good. Fingers crossed all the parts are correct then
  1. Question golf mk6 2.0tdi 2009 dmf to smf
    By daveyboy467 in forum Golf MK6 - 2009 - 2013
    Last Post: 08-03-2020, 06:56 PM
  2. 2.0tdi Avant rear tyre wear/suspension issue
    By petrolhead63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-03-2019, 10:41 PM
  3. Looking to buy used A4, 2009 estate, 2.0tdi, what to look out for?
    By WorldUK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-04-2016, 11:08 PM
  4. Has 2009 2.0TDI a CR engine?
    By Mike McKinstry in forum Golf MK5 - 2004 - 2009
    Last Post: 16-02-2015, 02:02 PM
  5. A6 3.0Tdi Quattro Creaking rear suspension over speed humps
    By gadget999 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-06-2013, 05:24 PM
