Thread: Spring Question
  1. Spring Question
    Apr 2018
    N.Ireland
    9 Post(s)
    So i ordered Vogtland Springs for the Saloon and got Avant ones... my fault but will they fit? they are a different part number but i'm not sure the difference if any?
    got VOG950028 should have got VOG950026
  2. Re: Spring Question
    May 2012
    Everywhere
    308 Post(s)
    Axle weights are everything..
  3. Re: Spring Question
    Apr 2018
    N.Ireland
    9 Post(s)
    Confirmed with the supplier wrong springs... apparently Avant spring will do the Quattro but not the FWD, lesson learned.
  4. Re: Spring Question
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    You can see here and here that the models they fit don't overlap:
    https://www.vogtland.com/en/search?sSearch=950026
    https://www.vogtland.com/en/search?sSearch=950028
    There's a whole load of VAG codes for springs on A4, Quattro, Avant, etc that don't overlap with usage. May fit the cups physically, but affect ride behaviour.
  5. Re: Spring Question
    Apr 2018
    N.Ireland
    9 Post(s)
    Just to follow up on this i got the correct springs fitted, Vogtland have to be the best out there without a doubt, the height is perfect and i'm so surprised that the ride is better than on audi springs! driving just feels easier now. Vogtland for life now.
  6. Re: Spring Question
    134 Post(s)
    2025 Post(s)
    In the days when suspension kits were all the rage, the brand I imported was Wietec but they went bust and were bought by KW so I started importing Vogtland but the market for fixed height kits started to dry up in favour of Chinese coil overs for £6.75 a car off eBay. I wonder if the fixed height quality kit is coming back as I am quoting on two now. Vogland offer Koni sometimes. The trouble is the UK's roads are in such a terrible state I am thinking of going back to 16's from 18's and raising the car... I have buckled two Alutec rims in a matter of weeks.
  7. Re: Spring Question
    May 2012
    Everywhere
    308 Post(s)
    Can't quite work out height adjustable coil over kits as the Joe Public people that fit them aren't suspension experts .
    Fixed height takes most of the guesswork out minus alignment .
    16-18" up sizing is ride height increase change in the real world .
    I'm on 18" with lower profile tyres than I would care for , but the ride quality even at 70K+ dampers is very acceptable , something to do with dual rate dampers or something .
    Alot depends on how well the spring rates are matched to the dampers .
  1. spring question
    By xantiaman in forum Bora - 1998 - 2005
    Last Post: 13-06-2013, 11:27 PM
  2. Question Key Fob Spring
    By A3 Sportback in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-10-2011, 03:24 PM
  3. Spring marking
    By m8gic in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-04-2011, 12:51 PM
  4. A3 Coil Spring Question
    By gorillamonsoon in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-09-2009, 08:51 PM
  5. Spring Meet?
    By tommyweaves in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-04-2008, 07:50 PM
