Thread: A8 D3 4.2TDI Starter just one click, help please
Results 1 to 10 of 13
  1. A8 D3 4.2TDI Starter just one click, help please
    Nov 2015
    GB, SOMERSET, TAUNTON
    Hello everyone. Have a strange thing happened. Before had no issue with starting the car ever. New battery also fitted and coded a month ago. Vcds have nothing related to the problem, that simply I can't start the car no more. Starter makes one click only. Took two starter relays 381 and one 370 out and droped in my mums car and its started, so relays are good. To get to starter is pain in the back big time. Any suggestions? Thanks again
  2. Re: A8 D3 4.2TDI Starter just one click, help please
    36 Post(s)
    847 Post(s)
    BMC or BVN? If it is a BVN, there is a two pin connector in the front right of the engine compartment with red/ black and black/yellow wires, the red/black is the line 50 starter motor trigger from the J695 starter relay 2, I could go MUCH deeper but I would need to know how good you are at car electrics or we could have smoke... I could do with the VIN as there are date changes for the wiring but the two starter relays J53 and J695 are driven directly by the engine ECU with socket 8 of relay 2 at position 3 being the output to the starer. I don't get the impression you have VCDS?
  3. Re: A8 D3 4.2TDI Starter just one click, help please
    Nov 2015
    HI CRASHER, I would love you to go deeper with anything you have to say, im quick learner and will take any gamble to test car before BIG JOB (STARTER). of course i have VCDS. ENGINE is BVN. CAR is 2010, i guess last **** edition . today checked the relays again(J53,J695 and the one in position 3) behind steering wheel resistance about 1-2ohm then activated, compared to new relay for air compressor, behaves the same. every fuse checked for continuity all ok. charged almost new battery to 13v holding charge. same voltage at battery cable behind driver carpet. got low battery warning, but after recoding battery disapiered. deleted all fault codes,done autoscan. locked the car unlocked after some time done scan again. also bypassed module between battery and battery cable, no luck. same click-clock on start up. will post full scan of the day she died and one of today. nothing really guides anywehere, GOD WHY???
  4. Re: A8 D3 4.2TDI Starter just one click, help please
    Nov 2015
    THE DAY SHE DIED
    Code:
    VIN: WAUZZZ4E3AN006951   Mileage: 228390km-141914miles
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    06-Seat Mem. Pass -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    11-Engine II -- Status: OK 0000
    31-Engine other -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    38-Roof Electronics -- Status: OK 0000
    3D-Special Function -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine        Labels: Redir Fail!
       Part No SW: 4E1 910 409 D    HW: 4E1 907 409 A
       Component: 4.2L V8TDI  G000AGMª0020
       Revision: --H05---    Serial number: AUX3Z0J1372180
       Coding: 0011773
       Shop #: WSC 02313 785 00200
       VCID: 2541E5AFEC8B2E67F6-8070
    1 Fault Found:
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 002 -
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 0
                        Fault Frequency: 5
                        Reset counter: 255
                        Mileage: 228396 km
                        Time Indication: 0
                        Date: 2020.03.23
                        Time: 00:00:19
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 3.9 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 0.4 %
                        Voltage: 11.55 V
                        Bin. Bits: 00101011
                        Torque: 171.6 Nm
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans        Labels: 09E-927-156.lbl
       Part No SW: 4E1 910 156 S    HW: 09E 927 156 B
       Component: AG6 09E 4,2 TDI RdW 0010
       Revision: --H01---    Serial number:        0135738
       Coding: 0000001
       VCID: 33650BF7525F40D768-8066
    No fault code found.
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 J    HW: 4E0 614 517 CP
       Component: ESP 5.7 allrad  H50 0540
       Coding: 0007557
       Shop #: WSC 02313 000 00000
       VCID: 2A5B16938595011FDB-807E
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
                000 - -
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 907 181 A
       Component:     FBS AUDID3  H12 0200
       Revision: 02005112    Serial number: AUX3Z0J1372180
       Coding: 0412672
       VCID: 58BF9C5BEB79438FBD-800C
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: ELV                 XXXX
    4 Faults Found:
    00179 - Access/Start Authorization Antenna; Drivers Side (R134)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 4
                        Fault Frequency: 0
                        Reset counter: 51
                        Mileage: 228144 km
                        Time Indication: 0
                        Date: 2020.03.16
                        Time: 13:24:40
    00180 - Access/Start Authorization Antenna; Passenger Side (R135)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 0
                        Reset counter: 51
                        Mileage: 228144 km
                        Time Indication: 0
                        Date: 2020.03.16
                        Time: 13:24:40
    00193 - Rear Right Door Handle Touch Sensor (G418)
                007 - Short to Ground
                 Freeze Frame:
                        Fault Status: 01100111
                        Fault Priority: 3
                        Fault Frequency: 10
                        Reset counter: 58
                        Mileage: 228144 km
                        Time Indication: 0
                        Date: 2020.03.16
                        Time: 13:50:22
    00955 - Key 1
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 4
                        Fault Frequency: 2
                        Reset counter: 95
                        Mileage: 228192 km
                        Time Indication: 0
                        Date: 2020.03.18
                        Time: 12:38:04
    Address 06: Seat Mem. Pass        Labels: None
       Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
       Component: Sitzmemory BFS H02  0010
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 4063840
       VCID: 2447F8ABE7B1D76FE1-8070
    Address 08: Auto HVAC        Labels: None
       Part No SW: 4E0 910 043 C    HW: 4E0 820 043 K
       Component: KLIMAAUTOMAT    017 0060
       Revision: 00000037    Serial number: 00000000170570
       Coding: 0088147
       VCID: 1D31CD4FC4DBE6A7AE-8048
    3 Faults Found:
    00066 - Rear Right Footwell Heater (Z43)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 58
                        Mileage: 224584 km
                        Time Indication: 0
                        Date: 2019.11.21
                        Time: 14:21:25
                 Freeze Frame:
                        Voltage: 14.60 V
    00065 - Rear Left Footwell Heater (Z42)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 58
                        Mileage: 224584 km
                        Time Indication: 0
                        Date: 2019.11.21
                        Time: 14:24:16
                 Freeze Frame:
                        Voltage: 14.60 V
    01206 - Signal for Duration of Ignition Off Time
                014 - Defective
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 58
                        Mileage: 224584 km
                        Time Indication: 0
                        Date: 2019.11.21
                        Time: 14:24:16
    Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
       Part No SW: 4E0 910 279 S    HW: 4E0 907 279 S
       Component: ILM Fahrer      H16 0240
       Coding: 0133121
       VCID: 387F3CDB4B39A38F5D-806C
       Subsystem 1 - Part No: 4E2 910 113 C
       Component: Wischer WWS D3  H60 0440
       Coding: 00000035
       Shop #: WSC 02313
       Subsystem 2 - Part No: 8K0 910 557   Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH04 0003
       Coding: 00139548
       Shop #: WSC 02313
    1 Fault Found:
    00908 - Control Module for Wiper Motor
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 1
                        Fault Frequency: 2
                        Reset counter: 98
                        Mileage: 0 km
                        Time Indication: 0
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
       Component: CDC-MP3-Pana  H49 0050
       Revision: 00000015
       VCID: 2149F1BF38A3C2478A-8074
    Address 11: Engine II        Labels: Redir Fail!
       Component: 4.2L V8TDI  G000AGSª0020
       Coding: 0011773
    Address 15: Airbags        Labels: 4E0-910-655-94.lbl
       Part No SW: 4E0 910 655 E    HW: 4E0 959 655 K
       Component:    Airbag 9.41  H01 4210
       Revision: 91H01421    Serial number: 003CU000Y50+
       Coding: 0431707
       VCID: 285FEC9B9B99330FCD-807C
       Subsystem 1 - Serial number: 63328RB4056AE7E90
       Subsystem 2 - Serial number: 63428RB4056AE773V
       Subsystem 3 - Serial number: 63528RB4056AE79F3
       Subsystem 4 - Serial number: 63628RB4056AE787
       Subsystem 5 - Serial number: 63729RB40490BDF5/
       Subsystem 6 - Serial number: 63829RB40490C7A9Z
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549 A    HW: 4E0 953 549 C
       Component: J0527               0530
       Revision: 00H07000    Serial number: 90025093520024
       Coding: 0112041
       VCID: 2643E2A3918D257FFF-8072
       Component: E0221           H02 0030
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 951 J    HW: 4E0 920 951 J
       Component: KOMBIINSTR. VDO H86 0640
       Revision: D06         Serial number: AUDID3J2100834
       Coding: 0032803
       Shop #: WSC 12345 067 57207
       VCID: 2C57108B8F611F2F29-8078
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4E0 910 105 A    HW: 4E0 815 069 H
       Component: Heizgeraet      H08 0160
       Revision: 0000000D    Serial number: 00000009013887
       Coding: 0000001
       Shop #: WSC 00000 000 00000
       VCID: 1A3BC653D5F5919F4B-804E
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0071
       Revision: 00H06000    Serial number: 1200B102238183
       Coding: FDF9DFFF20068E00
       VCID: 2D511D8FB47B16273E-8078
    1 Fault Found:
    00384 - Optical Databus
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 92
                        Mileage: 228056 km
                        Time Indication: 0
                        Date: 2020.03.10
                        Time: 18:26:18
    Address 28: HVAC, Rear        Labels: None
       Part No SW: 4E0 910 158 A    HW: 4E0 919 158 G
       Component: KLIMA-STG. FOND 017 0240
       Revision: 00000022    Serial number: 00000000089211
       Coding: 0000000
       VCID: 224BFEB3FDA5D95F93-8076
    Address 34: Level Control        Labels: 4E0-910-553.clb
       Part No SW: 4E0 910 553 K    HW: 4E0 907 553 H
       Component: LUFTFDR.-CDC    H07 4590
       Coding: 0015510
       VCID: 2B5513978A6F181720-807E
    2 Faults Found:
    01772 - Signal from Level Control Pressure Sensor (G291)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 95
                        Mileage: 228242 km
                        Time Indication: 0
                        Date: 2020.03.20
                        Time: 12:23:39
    01575 - Control Switched Off
                000 - -
                 Freeze Frame:
                        Fault Status: 11100000
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 228395 km
                        Time Indication: 0
                        Date: 2020.03.23
                        Time: 16:09:58
    Address 36: Seat Mem. Drvr        Labels: None
       Component: Sitzmemory FS  H02  0010
       Coding: 4063850
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Component: Dachknoten D3   H05 0090
       Serial number: 00001003900003
       Coding: 0036000
    Address 3D: Special Function        Labels: None
       Part No SW: 4E0 907 440     HW: 8K0 907 440
       Component: STS             H04 0050
       Revision: S0H04000    Serial number: 00000000010506
       Coding: 01010101000000000000000202
       VCID: 61C9B1BFB8238247CA-8034
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 802 F
       Component: Türsteuer.FS BRM005 0180
       Coding: 0032750
       VCID: 204FF4BBF3A9CB4F85-8074
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 E    HW: 4E0 907 289 E
       Component: Komfortgeraet   H11 0040
       Revision: 00400011    Serial number:  W041003080128
       Coding: 0004829
       Subsystem 1 - Part No: 4E0 907 719
       Component: Neigungssensor  H05 0020
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4E0 035 223 N    HW: 4E0 035 223 N
       Component: BOSE G3 D3    H01 0100
       Revision: AF001000    Serial number: 00000000001914
       Coding: 0F000000
       Shop #: WSC 02399 823 56573
       VCID: 2643E2A3518D257FFF-8072
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 D
       Component: ILM Beifahrer   H11 0070
       Revision:             Serial number: 00000000043087
       Coding: 0010101
       VCID: 1E33CA43C9DDFDBFB7-804A
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 801 F
       Component: Türsteuer.BF BRM005 0180
       Coding: 0032750
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
       Component: EPB  A4EC0230   H03 0230
       Revision: --H03---
       Coding: 0001031
       Shop #: WSC 00011 067 57207
    Address 55: Headlight Range        Labels: 4F0-910-357.lbl
       Part No SW: 4L0 910 357     HW: 4L0 907 357
       Component: AFS 1           H01 0060
       Revision: 00000001    Serial number:
       Coding: 0000018
       VCID: 69D9A99F4013CA0712-803C
       Subsystem 1 - Part No: 4F0 941 329 D
       Component: AFS-Modul links H01 0010
       Subsystem 2 - Part No: 4F0 941 329 D
       Component: AFS-Modul rechtsH01 0010
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4E0 035 061 D    HW: 4E0 035 061
       Component: Radio U DAB   H45 0024
       Revision: AB001007    Serial number: 333K$097518239
       Coding: 010103010000000000
       VCID: 1C37C04B1FC1EFAF59-8048
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4F0 919 129 C    HW: 4F0 919 129
       Component: HybridTV-DVB  H06 0390
       Revision: R0060000    Serial number: 76300802726301
       Coding: 03010000
       VCID: 2C57108B4F611F2F29-8078
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 4E0 035 670 C    HW: 4E0 035 670 C
       Component: H-BNT-EU      H47 0047
       Revision: --------    Serial number: 453LN097520001
       Coding: 010101000300D3FF4000070DFF7F00030000
       Subsystem 1 - Part No: 8R0 060 884 J
       Component: EUR 2010  1005
       Subsystem 2 - Part No SW: 4E0 919 604 A    HW: 4E0 919 604 A
       Component: DU7 High Alu  H43 0306
       Serial number: 9357LS091003922
       Subsystem 3 - Part No SW: 4E0 910 611     HW: 4E2 919 612 K
       Component: E0380 Bedient  H01 0050
       Serial number: 00000000090091
       Subsystem 4 - Part No: 8R0 906 961 A
       Component:   CD-Database  1293
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 92
                        Mileage: 228189 km
                        Time Indication: 0
                        Date: 2020.03.18
                        Time: 11:34:13
                 Freeze Frame:
                        Voltage: 12.70 V
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H12 0550
       Revision: 00000000    Serial number: 00000000000858
       Shop #: WSC 00976 210 82617
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  3003110131
       Coding: 344530393135313035412056413033303033313130313331
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
       Component: Türsteuer.HL BRM005 0180
       Coding: 0032750
    Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
       Part No SW: 4E0 910 441     HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J0210AJ
       Coding: 1020403
       VCID: 5CB7804B9F41AFAF99-8008
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 228396 km
                        Time Indication: 0
                        Date: 2020.03.23
                        Time: 00:01:22
                 Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
       Component: Türsteuer.HR BRM005 0180
       Coding: 0032750
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 D    HW: 4E0 919 283 C
       Component: Parkhilfe 8-Kan H12 0050
       Revision: 00H12000    Serial number: 11041006305056
       Coding: 0221008
    End-------------------------(Elapsed Time: 03:29)--------------------------
  5. Re: A8 D3 4.2TDI Starter just one click, help please
    Nov 2015
    TODAY
    Code:
    Thursday,02,April,2020,15:06:36:27176
    VCDS Version: 19.6.2.2 (x64)
    Data version: 20200210 DS308.0
    www.Ross-Tech.com
    VIN: WAUZZZ4E3AN006951   License Plate: DABAR VAVA
    Mileage: 228390km-141914mi   Repair Order:
    Chassis Type: 4E (4L0)
    Scan: 01 02 03 05 06 08 09 0E 11 31 15 16 17 18 19 28 34 36 38 3D
              42 46 47 4F 52 53 55 56 57 5F 61 62 6C 72 76
    5F-Information Electr. -- Status: OK 0000
    72-Door, Rear Right -- Status: Malfunction 0010
       Coding: 0011773
    1 Fault Found:
                   P1653 - 002 -
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 8
                        Reset counter: 255
                        Mileage: 228396 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:04:53
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 3.9 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 0.4 %
                        Voltage: 12.16 V
                        Bin. Bits: 00101000
                        Torque: 319.8 Nm
    Readiness: 0 0 0 1 1
       Coding: 0000001
       Coding: 0007557
    1 Fault Found:
                000 - -
       Coding: 0412672
       Component: ELV                 XXXX
    2 Faults Found:
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 0
                        Reset counter: 58
                        Mileage: 228384 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:02:34
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 0
                        Reset counter: 58
                        Mileage: 228384 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:02:34
       Coding: 4063840
       Coding: 0088147
    3 Faults Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 228396 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:11:26
                 Freeze Frame:
                        Voltage: 12.10 V
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 228396 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:11:26
                 Freeze Frame:
                        Voltage: 12.10 V
                014 - Defective
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 228396 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:11:26
       Coding: 0133121
       Coding: 00000035
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 98
                        Mileage: 0 km
                        Time Indication: 0
       Revision: 00000015
       Coding: 0011773
       Coding: 0431707
       Coding: 0112041
       Coding: 0032803
       Coding: 0000001
       Coding: 0000000
       Coding: 0015510
    1 Fault Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 228396 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:08:05
       Coding: 4063850
       Coding: 0036000
       Coding: 0032750
       Coding: 0004829
       Coding: 0F000000
       Coding: 0010101
       Coding: 0032750
       Revision: --H03---
       Coding: 0001031
       Coding: 0000018
       Coding: 03010000
       Coding: 0032750
       Coding: 1020403
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 228396 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:02:15
                 Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
       Coding: 0032750
    1 Fault Found:
    02126 - Central Locking Button; Exterior Door Handle
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 3
                        Fault Frequency: 0
                        Reset counter: 58
                        Mileage: 228384 km
                        Time Indication: 0
                        Date: 2020.03.25
                        Time: 00:14:22
       Coding: 0221008
    End-------------------------(Elapsed Time: 03:28)--------------------------
  6. Re: A8 D3 4.2TDI Starter just one click, help please
    Feb 2020
    Bradford
    15 Post(s)
    If the click is from starter solenoid, the battery is good, the main positive lead is secure, the quicker you get on your back the better cos the starter motor needs to be changed.
    If you need some temporary starts people used to advise tapping the starter with a hammer which might free it up temporarily but personally I have never tried this
  7. Re: A8 D3 4.2TDI Starter just one click, help please
    Nov 2015
    i would beleve that is starter if i had any issues with starting, but i never had, simply on the day i come to my garage lifted the rear, removed the wheel, put it back on and no start. taping the starter there is no enough clearance, as it buried deep inside, and change the starter is many many hours as subframe, etc need to come off. hence trying find help before comiting to this, just to find out later it is not a starter.
  8. Re: A8 D3 4.2TDI Starter just one click, help please
    Feb 2020
    Bradford
    15 Post(s)
    Quote Originally Posted by martynocarabaso View Post
    I feel your pain its a big job. Check the n253 battery isolation igniter. Worth a look for 12v and secure connection both sides on the large cables
  9. Re: A8 D3 4.2TDI Starter just one click, help please
    Nov 2015
    Quote Originally Posted by Roverfan View Post
    Did that already, tried to bypass it also still no crank, cleaned already clean conections B+ and put all back.
  10. Re: A8 D3 4.2TDI Starter just one click, help please
    Feb 2020
    Bradford
    15 Post(s)
    Is the click you hear from the starter solenoid?
    If yes, you have an almost certain diagnosis. For certainty it would require measurement at the starter but that is difficult
  1. 4.2tdi
    By bops6 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 26-07-2017, 07:40 PM
  2. Will A 4.2tdi Engine Fit in An A6?
    By as400 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-02-2013, 12:20 PM
  3. A4 3.00tdi v A8 4,2tdi
    By robtt09 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-07-2010, 08:49 AM
  4. a8 4.2tdi
    By scott007118 in forum A8 - S8 - V8
    Last Post: 13-03-2009, 08:54 PM
  5. Audi A8 4.2tdi
    By Parm in forum Chat - Anything with wheels
    Last Post: 16-12-2007, 08:11 PM
free web
stats
