Guys, 2011 A3 2.0TDI 170 quattro sport
Anyone got the correct torque settings for the various front lower arm bolts please ? Haynes seems to be in a right muddle with the torques.
There are 4 torque settings I need, I think all have a torque + angle tighten:
Rear alloy mount - this is 3 bolts, 1x12mm into the floorpan & 2x10mm into the alloy subframe.
Front bush mounting bolt - 12mm bolt through the centre of the front bush.
Ball joint 3 nuts.
TIA
John
