Thread: Passat B6 battery life?
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. Re: Passat B6 battery life?
    #21
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    There should be no additional cables on the battery so disconnect them and see what happens. If the Parrot is powered from these I would be surprised, it is easier to get the power under the dash.
    Right I'll disconnect that and see what happens, or indeed what doesn't happen! There are no other accessories on the car so I'll be damned if I know what it's for if it isn't the Parrot...
    2006 VW Passat 2.0 TDI (BKP) SE Estate
  2. Re: Passat B6 battery life?
    #22
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Well I've taken those two fuses out, but the Parrot still works! So I'm at a loss as to what that's for. Going to take it for a quick drive to make sure everything else still functions...
  3. Re: Passat B6 battery life?
    #23
    40 Post(s)
    897 Post(s)
    Has it got an aftermarket tow bar? That additional wiring is NOT OE! As I would have expected, the Parrot is wired up under the dash, taking it direct to the battery would have been daft.
  4. Re: Passat B6 battery life?
    #24
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Indeed it does, and I realised that shortly after posting on here!! It has dual electrics hence 2 fuses so that's what that is for, but there have been stories of incorrectly wired tow bar electrics draining a battery so I'll leave the fuses out and see if it makes a difference. I tow so rarely that it isn't a problem and I can put them back in when I do need the electrics.
  5. Re: Passat B6 battery life?
    #25
    Jan 2016
    Winchester Hants
    24 Post(s)
    Ref the AM tow electrics. Does your vehicle have a light on your dash to indicate a trailer/van plug is connected to the socket(s). Many moons back I had a Vitara with AM tow gear fitted by the dealer. The dash light decided to stay on even without a plug in the tow socket. I looked everywhere to find the fault but ended up taking the vehicle back to the dealer. They eventually traced the fault (and it took them a while) inside the tow socket was a plunger switch and it had jammed in (live). Even if you don't have an internal light the sockets may still have a switch which could be jammed and sending power somewhere.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFCG), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 48K (FSH), best Maxidot MPG 63. Cheat emission software. Nextbase 402G iN-CAR CAM.
  6. Re: Passat B6 battery life?
    #26
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Quote Originally Posted by UMEL View Post
    No it doesn't so it wouldn't make sense how it can draw power without anything physically being plugged in, as I don't know much about electrics but as far as I know it has to "go" somewhere not just into thin air... Although I did have connection issues last time I towed (I think corrosion on the socket/trailer plug) so could corrosion cause a parasitic drain?
    I'm purely stabbing in the dark here and that probably isn't my issue, but best rule it out first then go after the Parrot fuse, as if I unplug both now then I'll never know which was the culprit.
  7. Re: Passat B6 battery life?
    #27
    Jan 2016
    Winchester Hants
    24 Post(s)
    Quote Originally Posted by jmurray01 View Post
    Yes true but one never knows with electricity. All I know is you can't see it and it f'in well hurts when you touch it...the higher volts that is.
    Towing sockets are not in the best of positions so water and dirt does get in regardless of the cap. I too have to regularly spray both socket and plug with electrical contact spray before connection. Sometimes also using wet and dry.
  8. Re: Passat B6 battery life?
    #28
    Jan 2016
    Winchester Hants
    24 Post(s)
    Further to my post above, CTEK charger.
    They do eventually (after 5 or 6 days) get to Position 8.
    CTEK CS told me 10 days.
  1. Keyfob battery life
    By By-Tor in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-09-2013, 07:56 PM
  2. Battery Life ?
    By Redzer in forum Chat - Anything with wheels
    Last Post: 24-10-2008, 03:28 PM
  3. Sharan Battery life
    By Arty in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2008, 01:58 PM
  4. Battery life span
    By A6_JAck in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-09-2007, 04:04 PM
  5. Battery Life
    By Richardm in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:53 PM
