Thread: Cheap fix for faulty active exhaust
  1. Cheap fix for faulty active exhaust
    Sep 2014
    Manchester UK
    Last summer I realised that the active exhaust wasnít working on my 2013 Bitdi. A scan with VCDS gave the fault ĎActuator 1 open circuití. I checked the wiring and carried out a bit of research and it didnít seem to be a common fault but as the actuator is built into the rear silencer, I didnít fancy forking out £600 for a new one so decided to live with it.
    Fast forward to now where we are in lockdown and Iíve got a lot more time on my hands, I thought Iíd look into it again. I found a company in Germany that offered a repair service for £300, but as this required me to cut off my silencer and send it to them I decided it was too much hassle. However, a useful photo on their website showed a silencer cut open to reveal the inner workings. Very interestingÖ. The actuator is just a loudspeaker with the sound being piped to the tail pipe.
    I decided to connect an old spare speaker from a multimedia setup to the control unit and see what happened. The easiest way was to splice into the loom with scotchlock connectors near the plug to the controller. Terminals 5 and 6 are Actuator 1. I connected it up inside the boot, cleared the fault code with VCDS and started up. Success! Active exhaust working again.
    Now I had to decide where to put the speaker which is in an enclosure approx. 6 x 4 x 4 inch. Actuator 1 is on the passenger (left) side, so looking inside the storage panel I found a perfect space below the rear light. But even better, there is a 4 inch square air pressure vent in the back panel. This has gravity rubber flaps that I wedged open with a piece of foam and then my speaker fitted perfectly in the space, pointing the sound out through the vent which is behind the bumper about 6 inches above the tail pipe. I ran the cabling across the boot behind the rear trim.
    I started the engine and the noise externally is just as it should be, but a bonus is that the sound internally is much better than before. As the speaker is basically in the boot, you get a much better (louder) exhaust sound. Switch to Comfort mode and it turns off for more relaxed cruising.
    Iíve only managed a short test drive to the supermarket due to the current travel restrictions but Iím really happy with the result so thought Iíd share it with others as instead of spend upwards of £300 it cost me nothing.
    0 3 0
  2. Re: Cheap fix for faulty active exhaust
    Oct 2019
    Peterborough, England
    16 Post(s)
    The rubber flaps in the vent, are they to stop water ingress or will that be OK?
  3. Re: Cheap fix for faulty active exhaust
    Sep 2014
    Manchester UK
    I suppose strictly speaking yes. But looking at the design of the bumper and rear lights on the saloon, (not sure about the Avant) the lights overhang the bumper so shield any rainwater. The flaps are very light and open with no resistance so my theory is that whilst driving they will be open anyway to stop air pressure building up in the cabin. It is something I am going to keep an eye on but as it's garaged, and due to the current situation I haven't been out in the car since last week I don't know for certain. I'll post an update once I've had chance to drive it in the rain.
  4. Re: Cheap fix for faulty active exhaust
    Sep 2014
    Manchester UK
    Just for info, this is the picture I found of the inner workings of the Active exhaust.Active Exhaust.jpg
  5. Re: Cheap fix for faulty active exhaust
    Mar 2014
    Aylesbury Bucks
    11 Post(s)
    https://www.shutterstock.com/video/clip-2065526-playing-card-spokes-bicyclehttps://www.shutterstock.com/video/c...spokes-bicycle
  6. Re: Cheap fix for faulty active exhaust
    Mar 2014
    Aylesbury Bucks
    11 Post(s)
    Sorry for the last cheeky reply! But a loud speaker inside an exhaust........
  1. Loing Coding - Active Exhaust Audi A6 Allroad 2013
    By djrobski99 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-04-2019, 03:39 PM
  2. Active exhaust Kufatec plug and play
    By vdubm0d in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 06-05-2018, 09:05 AM
  3. Active Exhaust Control
    By DavidC_Surrey in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 23-12-2015, 03:05 PM
  4. Cheap exhaust system. Is this worth the risk??
    By mikecarty51 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-12-2011, 11:10 PM
  5. Chrome Exhaust covers - cheap
    By ScottyUK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-12-2010, 01:16 AM
free web
stats
