Thread: D3 suspension sensor question.
  1. D3 suspension sensor question.
    Oct 2019
    Peterborough, England
    19 Post(s)
    With a fault of:-
    00776 - Level Control System Sensor - Left Front
    012 Electical fault in circuit
    This error appears on my car. I bought a replacement sensor (on eBay) after I took the old one apart and found the connector was knackered with blue oxide, and one broken pin.
    I changed the connector too, and taped the cables together with electrical tape (temporary fix).
    However, the error is still there and will not be cleared.
    I will try another suspension sensor and see if that fixes it.
    Should the suspension sensor ‘lever’ be very easy to move or need a bit of effort to move them? As I have one that is very loose and the one I used was quite stiff to move.
    Other than that, any thing else I should look for?
    The suspension still goes up and down without issue.
    Thanks!
  2. Re: D3 suspension sensor question.
    Jun 2006
    UK, Registered Homeless
    Audi A8 Airsuspension fix - YouTube
    Diagnose Dan is good at this
    Audi A8L- 2006 - 3.0TDI
  3. Re: D3 suspension sensor question.
    Oct 2019
    19 Post(s)
    Update...
    I bought a crimp and some heatshrink things.
    When I undid the twisted cables from before, I noticed the cable threads were black. They were coated with something. 2 out of 3 cables were like this. I used some pliers to strip it off and expose the copper.
    Once crimped and heat shrunk, I drove home (I go to a little car park near by, as I do not have a drive). The yellow suspension light is still on, but the height and ride settings always worked anyway. But what I did notice, was that when I stopped and turned off, the car ‘settled’ and rose a bit, which it had stopped doing after my first intervention.
    Just need to try to clear the error and see if it returns. If it does, then I’ll swap the actual sensor out (as I have another).
  4. Re: D3 suspension sensor question.
    Mar 2011
    Derry
    On mine, when it was moved was free-ish. Not stiff but not loose either.
  5. Re: D3 suspension sensor question.
    Oct 2019
    19 Post(s)
    Thanks for the info.
  6. Re: D3 suspension sensor question.
    Oct 2019
    19 Post(s)
    Looks like I will need t9 change the sensor, as the error will not clear.
    Will give that a go on Sunday (maybe Saturday..?)
  1. Air Suspension Question
    By Milesunder in forum Q7 - 4M Forum - 2016 -
    Last Post: 07-07-2019, 09:22 PM
  2. suspension question
    By waynegts in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 01:38 PM
  3. Suspension question
    By Tobez in forum Golf MK3 - 1993 - 1999
    Last Post: 04-01-2012, 11:20 PM
  4. S4 suspension question
    By monkshood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2010, 10:43 AM
  5. suspension question..
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-02-2010, 10:04 PM
