Thread: Reduce oil level message
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Reduce oil level message
    Feb 2020
    Walmer UK
    Quote Originally Posted by robes401 View Post
    I also have an Ultra, and every time I have had it serviced (I've had 6 services now) it comes back with oil on max, but occasionally when I check the oil level within the first month or so after the service the 'please reduce oil level' is displayed. I've never removed any oil because this message doesn't appear every time so I assume it's just quite sensitive to small changes when on max rather that there being a significant overfill and issue.
    Thank you, I'm sure you're right. I spoke to an Audi independent garage yesterday and they said that if the oil had been seriously overfilled then there would be smoke coming out of the exhaust which thankfully hasn't been the case. I still haven't been able to locate the dipstick blanking plug though if anyone knows where this might be? I'm guessing I'd need to remove the engine cover to see it.
    Audi A6 Avant Tdi Ultra S Line 2014
  2. Re: Reduce oil level message
    1840 Post(s)
    My customer did not show, one of his children has the sweats and he went into lockdown.
  3. Re: Reduce oil level message
    Feb 2020
    Walmer UK
    Thank you, I did try to reply to your PM, but for reasons unknown any message I write doesn't seem to send. I've nothing in my 'sent' folder at all
  4. Re: Reduce oil level message
    1840 Post(s)
    Both your messages came through fine.
  5. Re: Reduce oil level message
    May 2018
    Kent
    7 Post(s)
    Morning, pull the engine cover off, the “dipstick pipe” is towards front right of engine as you look at it. I’ve had the message twice, only needs a small amount removed to correct it.
  6. Re: Reduce oil level message
    Feb 2020
    Walmer UK
    Quote Originally Posted by Artiglio View Post
    Thank you, I'll have a look later
  7. Re: Reduce oil level message
    #17
    Feb 2020
    Walmer UK
    There is a dip stick hole with a plug where you can use a...... dipstick but Audi in their infinite wisdom don’t supply one, Laser offer the one below
    Runtime Error (this is the link to the Laser tools page)
    I have just ordered one of these as clearly it's the only accurate way of measuring the oil level. Laser say that for post 2009 2.0 diesels the ring should be set at 46 but I've read a post on this forum that says it should be set at 70. I wouldn't have thought Laser would get this wrong, can someone using one of these with a Tdi Ultra engine please confirm?
  8. Re: Reduce oil level message
    #18
    Feb 2020
    Walmer UK
    The dipstick arrived and I tried it, but the oil level didn't seem to register so maybe the ring setting of 46 is wrong or maybe the oil is still too clean to see properly (only 240 miles since the oil change). Not that easy to get the dipstick in, requires a bit of force! However, the car is now saying the oil level is ok. it seems to catch some oil on various parts of the dipstick after removing it which doesn't help.
  1. Reduce oil???
    By DL78 in forum Q7 - 4M Forum - 2016 -
    Last Post: 14-02-2020, 11:19 PM
  2. Question Coolant level message but coolant is ok
    By Akash in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-07-2017, 12:08 AM
  3. Reduce oil level message
    By mattyholloway in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 06-04-2015, 03:12 PM
  4. oil level check message
    By cueboydave in forum Touareg
    Last Post: 24-01-2010, 03:35 PM
  5. Reduce emissions
    By cbrpaul in forum VCDS - General Questions
    Last Post: 05-05-2008, 02:47 PM
