Thread: Removing outside door trim
  1. Removing outside door trim
    May 2019
    Hereford UK
    Wonder if anyone can help with this.
    I want to remove the chrome strip at the top of the "door skin" on my 2008 Golf Mk5 Estate (which is an import from Japan). Door skin in quotes because the door is welded - the skin isn't removable.
    The door is damaged and I want to transfer the trim to a s/h door and fit that..
    Can anyone advise how to remove the trim without ruining it!
    Photo shows which trim I'm talking about.
    Thanks. Dave.
  2. Re: Removing outside door trim
    1841 Post(s)
    The Golf 5 door skin is unique to VAG in that it is bolted on, except the estates rear door... I have never removed one but I will look it up for you at work tomorrow as the trim 1K9 839 644 A 2ZZ is £115.76
  3. Re: Removing outside door trim
    May 2019
    Hereford UK
    Great thanks!
    I've found a parts list now. Looks like your number is for the trim at the top of the door though. The number I came up with was 1K9 839 475 (or 476) A 2ZZ for the strip just below the window glass.
  4. Re: Removing outside door trim
    1841 Post(s)
    Yes I was using my iPad and clicked up the upper strip in error.
  1. Removing inside door trim
    By Boat_face in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-12-2015, 09:54 AM
  2. Removing inner trim from front door
    By cycling_caveman in forum Golf MK3 - 1993 - 1999
    Last Post: 09-04-2009, 08:51 PM
  3. Removing The Outer Door Trim
    By mikel1 in forum Golf MK3 - 1993 - 1999
    Last Post: 08-10-2008, 07:01 PM
  4. Removing plastic trim on sill of the door
    By sheka in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2008, 08:47 AM
  5. Removing interior door trim
    By kow in forum Audi A3 - Archive Topics
    Last Post: 23-09-2007, 10:29 PM
