Thread: Comfort control module
Results 1 to 10 of 12
  1. Comfort control module
    Dec 2009
    sheffield
    Good morning all
    forgive me, this may have been covered a few times
    I have an A4 B7 convertible 2007 2.0 TDI S Line
    The car has been parked up for a few months now with the odd start up over winter period and a few runs up and down the drive to make sure the brakes are not sticking on
    I decide for give the old girl some TLC ready for the coming summer months ( hopefully)
    The battery had gone flat, so I charged it up and put it back in place, but didn’t replace the black plastic cover properly.
    water has come in, ran under the passenger side and into the rear footwell. ( car parked facing upward on drive )
    The amount of waster under the carpets was quite surprising.......I even poured waster out of the comfort control module under the passenger carpet
    I’ve since dried everything out and reconnect everything and check for error on a small hand held scanner
    I’m faced with electrical issues which I believe is from the comfort control module
    I can’t seem to clear the codes down from my small scanner as they keep returning. ( all 19 of them )
    these relate to central locking, interiors lights, fuel flap lock, alarm, Keys
    01330 01616 01368 01357
    01317 00963 01369 00955
    01336 01370 01371 00956
    01134 00962 00892
    I’m currently in the process of obtaining a Ross tech scanner to do a full scan to confirm the module it’s completely knackered
    my question is
    The module is 8H0 959 433 K I know the next version up has an “M” on the end which would need programming anyway,
    these are hard to find... and cost a small fortune
    could I purchase a unit this has come off a A4 B7 model S line or even B6 (perhaps not a convertible ) and reprogram this unit to suit?
    I noticed some units are not fully pinned and thinking this is down to the model specification, but as long as I get a fully pinned unit
    Or something with a different ending letter ...would this work the same once reprogram.
    I’ve seen this on eBay
    AUDI A4 B7 S-LINE 2.0 TDI TDSFI 2004-2008 CONTROL MODULE 8E0959433CQ ,00002731E3
    Any help would be much appreciated
    regards
    Richard.........
  2. Re: Comfort control module
    1836 Post(s)
    The incontinence unit (they always seem to be wet) may recover with some contact cleaner and being died out, I blow then dry with an air line and then heat them up with a hair drier and they usually recover. Your fault could be a corroded wiring junction in the harness a few inches back from the unit.
  3. Re: Comfort control module
    Dec 2009
    sheffield
    Hi Crasher
    thank you for the reply
    ive checked for corroded wires back to the contact blocks, everything looks ok
    I’ve sprayed all connections with contact cleaner and done the same with the CCM ( after taken apart again )
    replace everything, but still having problems, the unit starts to click and flashed the glove box light as if it’s got a bad earth
    below is the full scan I took today, can please have a look and confirm my suspension it’s the module that’s gone
    before a get another one, I might give the CCM the once over with the soldering iron and magnifying glass in case I’ve missed any dry joints
    many thanks
    Richard.....
    Tuesday,24,March,2020,16:53:22:00009
    VCDS -- Windows Based VAG/VAS
    VCDS Version: 19.6.2.0
    Ross-Tech: Home
    VIN: WA####8H######### License Plate:
    Mileage: 170760km-106105mi Repair Order:
    Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
    63 65 67 73 75 76 77
    Address 01: Engine Labels: 03G-906-016-BPW.clb
    Part No SW: 03G 906 016 KN HW: 03G 906 016 KN
    Component: R4 2,0L EDC G000SG 9748
    Revision: --H05--- Serial number:
    Coding: 0000072
    Shop #: WSC 00672 785 00200
    VCID: 79F3B02630D95B87E0-802C
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes Labels: 8E0-910-517.clb
    Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004405
    VCID: 2C5D59728F0B3E2F2B-8078
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0222
    Hex Value: 0x0024
    Hex Value: 0x0192
    Hex Value: 0x0001
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 3233
    Coding: 00100
    Shop #: WSC 00672
    VCID: 6CDD99721C8BFE2F6B-515A
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    49-10 - No Communications - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 N
    Component: int. Lastmodul ECE 0907
    Coding: 20001
    Shop #: WSC 00503
    VCID: 3D7B64363771A7A78C-4B32
    1 Fault Found:
    Address 15: Airbags Labels: 8H0-959-655-94.lbl
    Part No SW: 8H0 959 655 E HW: 8H0 959 655 E
    Component: Airbag 9.42 H10 1840
    Revision: 92H10184 Serial number: 0037Y000PU7K
    Coding: 0071114
    VCID: 3C7D69327F6BAEAFBB-8068
    Subsystem 1 - Serial number: 6332BRB401E95BE4$
    Subsystem 2 - Serial number: 6342BRB401E95C16U
    Subsystem 3 - Serial number: 63729RB401E93DAF5
    Subsystem 4 - Serial number: 63829RB401E93D52V
    1 Fault Found:
    01218 - Side Airbag Igniter; Passenger Side (N200)
    001 - Upper Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0701
    Coding: 02041
    Shop #: WSC 00672
    VCID: 418318C64B89C347E8-4B18
    1 Fault Found:
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8H0 920 951 D HW: 8H0 920 951 D
    Component: KOMBI+WFS 4 H14 0200
    Revision: 0200 Serial number: 00000000000000
    Coding: 0006411
    Shop #: WSC 00732 210 90008
    VCID: 2E59537ABA174C3F05-5178
    1 Fault Found:
    Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
    Coding: 0006411
    VCID: 2E59537ABA174C3F05-515A
    1 Fault Found:
    Address 26: Auto Roof Labels: 8H0-959-255.lbl
    Part No: 8H0 959 255 A
    Component: VSG B6 CABRIO 7094
    Shop #: WSC 00503 210 81333
    VCID: 346D4112543B66EF73-515A
    7 Faults Found:
    02000 - Switch Position
    008 - Implausible Signal
    01989 - Hardtop Detector Switch (F255)
    01317 - Control Module in Instrument Cluster (J285)
    00470 - Company Comfort Databus in Single Wire
    00532 - Supply Voltage B+
    02023 - Terminal 87
    008 - Implausible Signal - Intermittent
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8H0 951 178
    Component: Innenraumueberw. 0411
    Coding: 00001
    Shop #: WSC 00000
    VCID: 6FE78E7E2D9D05374E-5120
    Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
    Part No: 8H0 959 433 K
    Component: Komfortgerát T3B 5241
    Coding: 06831
    Shop #: WSC 00672
    VCID: 3C7D69322C6BAEAFBB-4B18
    Subsystem 1 - Part No: 8H2959802D
    Component: Tõrsteuer.FS BRM 0205
    Subsystem 2 - Part No: 8H2959801D
    Component: Tõrsteuer.BF BRM 0205
    Subsystem 3 - Part No: 8H0959801A
    Component: Tõrsteuer.HL BRM 0002
    Subsystem 4 - Part No: 8H0959802A
    Component: Tõrsteuer.HR BRM 0002
    6 Faults Found:
    01134 - Alarm Horn (H12)
    28-00 - Short to Plus
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01357 - Tank Flap Locking Motor (V155)
    29-10 - Short to Ground - Intermittent
    00955 - Key 1
    35-10 - - - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8E0 035 186 AK HW: 8E0 035 186 AK
    Component: R Concert2+ H02 0220
    Revision: 00H02000 Serial number: AUZ1Z3F0302587
    Coding: 0210331
    VCID: 70E58D0260A31ACF57-5178
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 14
    Time Indication: 15
    End-------------------------(Elapsed Time: 07:27)--------------
  4. Re: Comfort control module
    1836 Post(s)
    You have a lot of low voltage issues there.
  5. Re: Comfort control module
    Dec 2009
    sheffield
    Hi Crasher
    Yep, the battery had run flat over the winter, put it on charge and the car starts up fine
    this scan may have been taken without the engine running to be honest
    One of the relay on the CCM board starts clicking. the ignition is off and key out,
    it only starts clicking after the interior lights have dim out and you then open the glove box or switch the interior lights on
    ...close the glove box or turn the lights off it stops, put the key in switch ignition on or open any door it stops
    ive got no locking of the fuel cap, alarm sound or working cab roof, ....I’ve eliminate the fuses as they have tested all ok
    not too sure where to go now
    cheers
    Richard
  6. Re: Comfort control module
    1836 Post(s)
    Do another scan with it running.
  7. Re: Comfort control module
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    So if you open door to turn lights on no clicking, but flick cabin switch for same lights and it clicks?
  8. Re: Comfort control module
    Dec 2009
    sheffield
    Hi Crusher / 1st Gear
    Thanks for the reply
    So, gone out and plugged in the CCM with the battery still connect
    did not started engine up and ran a scan the below scan.....
    Saturday,28,March,2020,16:21:09:00009
    Data version: 20190930 DS308.0
    Ross-Tech: Home
    VIN: WAUZZZ8H77K0***** License Plate: 10th SCAN NO ENGINE
    VIN: WAUZZZ8H77K0***** Mileage: 170760km-106105miles
    Coding: 0000072
    Coding: 0004405
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 15
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0222
    Hex Value: 0x0024
    Hex Value: 0x018A
    Hex Value: 0x0001
    Coding: 00100
    Shop #: WSC 00672
    1 Fault Found:
    Coding: 20001
    Shop #: WSC 00503
    1 Fault Found:
    Coding: 0071114
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Coding: 02041
    Shop #: WSC 00672
    1 Fault Found:
    Coding: 0006411
    Coding: 0006411
    VCID: 346D4112543B66EF73-5178
    2 Faults Found:
    02023 - Terminal 87
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    01349 - Alarm via Theft Warning System; Front
    43-00 - Closed
    Coding: 06831
    Shop #: WSC 00672
    VCID: 3C7D69322C6BAEAFBB-4B32
    19 Faults Found:
    49-00 - No Communications
    01333 - Door Control Module; Rear Left (J388)
    01334 - Door Control Module; Rear Right (J389)
    01320 - Control Module for Climatronic (J255)
    01336 - Company Data Bus for Comfort System
    37-00 - Faulty
    01616 - Signal Wire to Interior Monitor
    79-00 - Please Check Fault Codes
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    29-00 - Short to Ground
    00955 - Key 1
    00466 - Control Module for Steering Column Electronics (J527)
    00457 - Central Electronics Control Module / BCM (J519)
    00830 - Convertible Top Control Module (J256)
    Coding: 0210331
    End-------------------------(Elapsed Time: 07:25)--------------------------
    When the scan finished, I cleared all the faults down
    Turned the engine off and then took the key out
    Then re stared engine again and run a fresh scan which is what you can see below
    don't worry too much about the air bag error as the passenger seat is out of the car at the moment....
    Saturday,28,March,2020,16:48:48:00009
    Ross-Tech: Home
    VIN: WAUZZZ8H77K0****** License Plate: 10th SCAN ENGINE NOW RUNNING
    Coding: 0000072
    Coding: 0004405
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4222
    Hex Value: 0x0024
    Hex Value: 0x01B1
    Hex Value: 0x0001
    Coding: 00100
    Shop #: WSC 00672
    Coding: 20001
    Shop #: WSC 00503
    Coding: 0071114
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Coding: 02041
    Shop #: WSC 00672
    Coding: 0006411
    Coding: 0006411
    Coding: 00001
    Shop #: WSC 00000
    VCID: 6FE78E7E2D9D05374E-513C
    Coding: 06831
    Shop #: WSC 00672
    1 Fault Found:
    Coding: 0210331
    VCID: 70E58D0260A31ACF57-515A
    End-------------------------(Elapsed Time: 07:21)--------------------------
    So if I stop the engine with the key in the ignition ( ready to pull out, Position 1 I think ) with the glove box open,
    The glove box light flashes to the same sequence as the relay clicking on the CCM
    if i now turn on the interior lights, these also flash to the same sequence as the glove box light and clicking relay on the CCM
    push interior lights off and close the glove box, the relay clicking on the CCM stops
    open the glove box or turn the interior lights on the CCM relay starts clicking again,
    if i now open a door while its clicking. it stops..... as the interior lights come back on, close the door and watch to the interior light to fade out, then turn the interior lights back on again or open the glove box the CCM start clicking again
    pull the key out and the interior lights come on, ( no clicking ) but once they have faded out.....then turn them on, the clicking starts or open the glove box
    Close glove box and turn interior lights off the CCM stops,
    Turning the driving lights on in any combination does not have any effect on the CCM....no clicking,
    this seem to be linked to the interior lights but only when they have faded out
    hope this helps
    Richard............
  9. Re: Comfort control module
    1836 Post(s)
    Did you open up the harness to access the power feed multiple connections point, this is a 4B but it is similar.Is the earth on the floor clean?
    This is a Superb 1 so a little closer
  10. Re: Comfort control module
    Aug 2011
    Aldershot
    6 Post(s)
    Sorry to hi-jack your thread, can you confirm the convenience module location for me? I've seen a youtube video but it's a left hand drive car and it's in the drivers Left footwell, but I'm assuming on a right hand drive car, it's still in the left footwell?
    Is the convienience module under the seat, or is it more at the front of the passenger footwell? I can't find a picture online exactly where this is located before I go digging?
    Also would you know if the bluetooth module is in the same waterproof box? or is there another box in one of the footwells for this?
    Paul
  1. comfort control module
    By nigel63 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-01-2014, 03:31 PM
  2. Comfort control Module
    By Snaga in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-08-2012, 02:04 PM
  3. comfort control module
    By logic5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-02-2010, 05:54 PM
  4. Please Help Comfort Control Module
    By VWP02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2009, 05:11 PM
  5. Where is my Comfort Control Module (CCM)
    By Digidick in forum Toledo
    Last Post: 24-10-2008, 06:22 AM
