Thread: Audi A7 Failed MOT headlamp beams different patterns strange !!
Results 1 to 9 of 9
  1. Audi A7 Failed MOT headlamp beams different patterns strange !!
    Jun 2019
    Cambridgeshire, UK
    All,
    I've been searching across various sites but not found anything too helpfull and hoping someone can help me resolve a really strange problem on my 2014 A7 which has xenon plus headlamps.
    In it's MOT test it failed as the passenger side and driver side headlamps have different paterns which I initially thought could be MMI related but seems more to be I might have an incorrect headlight unit which is a bit odd to say the least.
    Is there a way to establish this without ripping the car to bits to check what the units are each side ?
    Also does anyone know if there is a any sort of history kept by Audi on what left the factory as I can't help think this may have been a production issue if one of the lights is indeed the wrong unit.
    thanks.
  2. Re: Audi A7 Failed MOT headlamp beams different patterns strange !!
    1840 Post(s)
    Private message me your REG and I can tell you what the part numbers should be for the car.
  3. Re: Audi A7 Failed MOT headlamp beams different patterns strange !!
    1840 Post(s)
    Your headlights should be 4G8941043A left and 4G8941044A right. Because they are £893.76 each, if damaged people tend to cut corners.
  4. Re: Audi A7 Failed MOT headlamp beams different patterns strange !!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    So that's the 4th MOT? Can you take it to same test station as last year (assuming you didn't already)?
  5. Re: Audi A7 Failed MOT headlamp beams different patterns strange !!
    Jun 2019
    Cambridgeshire, UK
    Thanks for the part numbers I'll check what they are. Do you know which part shapes the beam i.e. is it possible to re-use the bulb, ballast etc and get the outer shell part ?
  6. Re: Audi A7 Failed MOT headlamp beams different patterns strange !!
    Jun 2019
    Cambridgeshire, UK
    I did wonder if I could get it through by revisiting the same place that did it last year however as I plan to keep the car for a few years I'm thinking I will try and resolve the issue as cheaply as possible.
  7. Re: Audi A7 Failed MOT headlamp beams different patterns strange !!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Quote Originally Posted by cdg123 View Post
    If you also think they're different that make sense. I wasn't sure if there was a margin of individual tester opinion that you're on the edge of.
  8. Re: Audi A7 Failed MOT headlamp beams different patterns strange !!
    1840 Post(s)
    We did an R32 that had a near side beam pattern problem, the only cure was a new unit. Firstly I would check the bulb is the correct D3S-42V35W specification of good quality and fitted properly. Because the genuine bulb is £182.17, people cut corners.
  9. Re: Audi A7 Failed MOT headlamp beams different patterns strange !!
    Jun 2019
    Cambridgeshire, UK
    OK thanks again for the info I'll check everything out this evening / tomorrow.
  1. Seat Ibiza 1.4 BKY Misfire, Scope patterns!
    By zmotor in forum Ibiza - Cordoba
    Last Post: 28-06-2016, 05:27 AM
  2. Headlamp H7 Failure! - Strange Rubber Tube?
    By Pauls898 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-05-2013, 04:32 PM
  3. 2003 Audi A4 1.8T Avant ( High Beams turning on and off on own?!)
    By FrozenAvant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2011, 06:34 PM
  4. Headlamp washers failed?
    By bobwmac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-04-2011, 05:59 PM
  5. Failed headlamp bulb
    By dishy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-08-2008, 01:45 PM
