Thread: Corrosion and rust - front wheel arch
  1. Corrosion and rust - front wheel arch
    Aug 2009
    glossop
    Hi everyone,
    Just about to clean my car and noticed quite a lot of rust on the front wings of my a4 2.0 TDi avant. I appreciate the car is nearing 11 yesrs old and that this front wing rust/corrosion does appear to be a common problem.
    Knowing that there is a 12 year corrosion warranty, has anyone on here been able to succesfully make a claim against this recently, or is it a case of suck it up and pay for the repair myself? Would you recommend replacement wing or get it treated and painted?
    Also, I have a question about the front wheel arch linings. I noticed there is a big gap in the wheel arch liner, behind the front suspension components. Is this normal or should there bea an additional wheel arch panel fitting being the components to cover up the bodywork behind it (see image below)?
    It was a bit difficult to take a proper picture, but here it is. The black wheel arch linr can be seen in the bottom left hand corner of the image, but then the inner wing can be seen behind the spring. Is this normal on a b8 avant? If it is, should I get this treated and resprayed at the same time as the wing?
    Many thanks in advance.
  2. Re: Corrosion and rust - front wheel arch
    May 2012
    Everywhere
    308 Post(s)
    Terribly rusty cars .
  3. Re: Corrosion and rust - front wheel arch
    1840 Post(s)
    Is that real, intentional or fake?
  4. Re: Corrosion and rust - front wheel arch
    Sep 2011
    Kilmarnock, United Kingdom
    12 Post(s)
    I’m sure it’s vinyl wrap
  5. Re: Corrosion and rust - front wheel arch
    1840 Post(s)
    Yes, the rust on the drivers side is shiny.
  6. Re: Corrosion and rust - front wheel arch
    Aug 2009
    glossop
    Thanks for the responses everyone. Suspect this will jot be covered under Audi warranty so will take to a local body shop to see what they advise - whether they can treat and respray or whether it needs a new front wing.
  1. Audi A6 rust on rear wheel arch
    By invisiblekid75 in forum Body Work, Body Styling and Body Kits
    Last Post: 23-06-2014, 04:08 PM
  2. Replies: 1
    Last Post: 04-01-2013, 01:56 PM
  3. Question Front wheel arch liners
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2012, 08:29 PM
  4. rust appearing on wheel arch
    By drayman06 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-03-2009, 09:00 PM
  5. front wheel arch liners
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-02-2009, 06:57 PM
