Thread: Help please - alhambra / sharan po299
  1. Help please - alhambra / sharan po299
    Mar 2020
    brighton
    Hey Guys,
    I’m new on here but could sure use some help. Please!!! My car is a 2012 2.0 Seat Alhambra. 103Kw 140BHP (50,000 miles)
    Around 2 months ago I got stuck in mud and my wheels were spinning a lot. I eventually got out with some pushing.
    On the drive home after on the motorway the car went into limp mode with the coil light etc. (first time ever) The fan is also very noisy in the engine bay even after short journeys.
    Anyway, now when I drive the car and the revs hit 3000rpm it cuts in to limp mode straight away. I have to turn ignition off to reset it.
    So, I went to my local mechanic (very experienced) and we get the fault code PO299. Turbo under boost.
    SO FAR WE HAVE CHANGED (in change order) -
    - EGR VALVE
    - TURBO PRESSURE SENSOR
    - TURBO ACTUATOR
    - TURBO CLEANER
    - ADD BLUE INJECTOR
    - SMOKE LEAK TEST
    - CARBON CLEAN THROUGH
    - TURBO
    So I'm at a loss. I have spent a near fortune on this now and am hoping one of you lovely people maybe able to shed some light on it.
    The only things I can see to try are
    - Double check leaky hoses ?
    - Turbo Diverter valve ?
    - Clogged air filter ?
    Thanks so much,
    Matt W
  2. Re: Help please - alhambra / sharan po299
    Nov 2020
    Denmark
    Hi Matt
    What was the problem? Have you fix it yeat? I have same problem, limp mode po299, have replaced: Dpf filter, turbo, acuator, map sensor, erg acuator, dpf sensor.....
    Best regards Jon
    Seat Alhambra 2012 170hp Tdi
  3. Re: Help please - alhambra / sharan po299
    Nov 2020
    Uk
    Hello guys...
    Have yous managed to fix this fault yet
  1. Sharan / Galaxy / Alhambra
    By renamecor in forum Touran - Sharan - Caravelle
    Last Post: 14-08-2011, 10:27 PM
  2. New Sharan / Alhambra.
    By Team Green in forum Touran - Sharan - Caravelle
    Last Post: 15-02-2011, 10:06 PM
  3. Question Alhambra or Sharan Manual
    By Mike-G in forum Alhambra
    Last Post: 10-12-2009, 10:30 AM
  4. Please Help Alhambra/Sharan engine pre heaters
    By David Fox in forum Alhambra
    Last Post: 07-11-2009, 03:23 PM
  5. need a MkII Sharan or Alhambra breaking urgently
    By andy1020 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 29-10-2009, 11:06 PM
