Thread: Starter motor replacement
  1. Starter motor replacement
    Feb 2017
    Norway
    My 1998 2.4 saloon FWD will not start. Not a sound from the starter when turning the key. I've tried with spare key, the same. Funny thing though, with a battery booster it started right away. So, I replaced the battery since it was kind of old and had low voltage even when fully charged, but it didn't change anything. Still total silence.
    Thought I should test if starter gets power (terminal 50) from the ignition switch, but I can't even get to the connector. Tight. What's the procedure for replacing the starter? I would love to have the right sequence. Thanks.
  2. Re: Starter motor replacement
    Feb 2020
    Bradford
    40 Post(s)
    Quote Originally Posted by MeDriving View Post
    You can always test at the starter. Since you hear no sound at all it still leaves the possibility the signal is not reaching the solenoid.
    (Take precautions the vehicle will not move forward if the starter operates, protect yourself from possible arcing/shorting of the starter to its body)
  3. Re: Starter motor replacement
    1836 Post(s)
    It is alternator off first and then you can get at the starter, I havn't done one in years but it is a painful job and if I had to do it on the deck I simply wouldn't! manual or auto?
  4. Re: Starter motor replacement
    Feb 2017
    Norway
    @Roverfan Yes, I thought it was a good idea to test at the starter first (terminal 50) to check for signal from the ignition switch, but it's insanely hard to access.
    Thanks for your advice.
    @Crasher It's an auto. I have the Bentley Publishers manual and all it says is to disconnect battery terminal, starter and solenoid wires, then remove starter mounting bolts and lift out the starter. Easy peasy, right? Not. Since I'm working on the deck I think I'll give this one to the repair shop. Thanks for your advice.
  5. Re: Starter motor replacement
    1836 Post(s)
    Power the starter from the red/black wire in the ecu box where the J207 starter relay is, relay 4 plate socket 8
  6. Re: Starter motor replacement
    Feb 2017
    Norway
    Hey, great tip. Thanks.
  1. Question 2.0 tdi manual starter motor replacement
    By Audis_Win in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-06-2016, 03:48 PM
  2. Battery replacement - starter motor making sound
    By jalz in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-01-2012, 03:46 PM
  3. Question replacement starter motor
    By DropKickMurphy in forum Golf MK2 - 1984 - 1992
    Last Post: 23-03-2011, 04:45 PM
  4. Replacement Starter Motor
    By steve4586 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-05-2009, 10:05 PM
  5. Which replacement starter motor?
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-01-2008, 01:33 PM
