Thread: How long did your battery last?
Results 1 to 9 of 9
  1. How long did your battery last?
    Nov 2008
    Milton Keynes
    Hi guys, battery has just failed on 66 plate, 59,000 mile A6 Avant. I was expecting it to last a bit longer than 3 1/2 years to be honest as never changed a battery so soon ever before (and £350 for new one stings a bit!!!) Just wondering if I'm expecting too much and this is about right or if it's failed unusually early? What do you reckon?
  2. Re: How long did your battery last?
    1841 Post(s)
    Very early by modern standards, who says it has failed? At £1161.62, I hope the 48v battery lasts longer.
  3. Re: How long did your battery last?
    Nov 2008
    Milton Keynes
    Thanks for reply Crasher. The recovery guy said it had failed due to over-charging caused by alternator issue. Then took it to Audi dealership and their diagnostic just said it had failed and nothing to do with alternator!?! I have 1 year extended warranty but battery not covered.
  4. Re: How long did your battery last?
    1841 Post(s)
    What happens WHEN (not if) a faulty high speed charger damages you EV high voltage battery and other parts such as the charge controller, when the charger company and the cars manufacturer say it is the other companies fault? Who picks up the easily £30k bill on an in warranty e-tron? It is not a case of IF it will happen but HOW MANY TIMES? EV’s are a dead end solution...
    0 2 0
  5. Re: How long did your battery last?
    Nov 2018
    Tamworth
    22 Post(s)
    It would make an interesting small claims court action. Nothing whatsoever to do with any warranty. I think you would, however, need an "expert" report on both the battery and the charging system to show exactly what has failed.
    It would then be up to the Judge to decide if it's reasonable for it to fail given your particular circumstances, or not.
    I think less than 5-6 years for a battery in normal use is pathetic.
    Andy.
  6. Re: How long did your battery last?
    Mar 2016
    Minervois, France
    53 Post(s)
    Lead-acid batteries tend to last longer if they are kept as fully charged as possible - ignore anyone who tells you they should be "cycled".
    Our Audi is kept in the garage, and every time I park it there I plug in a little CTEC 0.8 amp automatic charger, which is permanently connected to the battery.
    It's not really much of a chore, I did forget to disconnect it a couple of times, but it is connected to an extension cord, and continental plugs and sockets separate easily, so no harm done.
    Last edited by FrenchAudi; 17-03-2020 at 12:20 PM. Reason: Put in correct size of charger
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  7. Re: How long did your battery last?
    1841 Post(s)
    Quote Originally Posted by AndyN01 View Post
    The warranty for the £30K e-tron battery is 8 years or just under 100k miles, then they wash their hands of it.
  8. Re: How long did your battery last?
    Nov 2008
    Milton Keynes
    Thanks for all your replies and I have an update. I contacted Audi UK customer service today to see whether they would offer any goodwill and to my surprise they contacted the dealership and a)negotiated the price down from £350 to £300 and then b) gave me £250 goodwill gesture meaning my total bill was £50. A good result in my book.
    0 7 0
  9. Re: How long did your battery last?
    Jun 2020
    Manchester
    Great News
    I have been through the same issue.
    New battery at just over 3 yrs.
    Had 02252 generator issue and this was from 28000 miles.
    At last got this fixed and the fault is not the Alt or batt but a faulty wiring loom cable going to the alt.
    Thus always under charges and does not boost the AGM batt to correct voltage.
    It is not repeat not the voltage regulator.
    Hope the above helps people out happy motoring keep safe.
  1. How long the battery can keep up in the winter?
    By MacUsers in forum Q7 - 4M Forum - 2016 -
    Last Post: 28-11-2018, 01:52 PM
  2. How long the battery holds the changes?
    Last Post: 29-07-2017, 10:29 AM
  3. How long does the battery on an A6 last via ciggy lighter?
    By Akash in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2012, 04:04 PM
  4. Touran- Battery light comes on over 80MPH on long journeys
    By ProDave in forum Touran - Sharan - Caravelle
    Last Post: 08-08-2011, 07:35 AM
  5. Replies: 0
    Last Post: 22-01-2011, 02:06 PM
