Thread: HCK Gearbox oil
Results 1 to 9 of 9
  1. Question HCK Gearbox oil
    Mar 2014
    Nottingham. UK
    Am I correct in saying the HCK gearbox requires 75w 90 fully synthetic oil?
    Also what is gl4 - gl5 oil? I'm assuming the HCK box requires gl4? I've heard you shouldn't swap one for the other as they have different properties.
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  2. Re: HCK Gearbox oil
    May 2012
    Everywhere
    308 Post(s)
    Alot of Internet oil misinformation due to lack of knowledge...
    4F or 4G , and engine code ?
    75W90 ( G 052 911 ) is probably right but too thick when cold and Fuchs own take on this is 75W80 .
  3. Re: HCK Gearbox oil
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by Gazwould View Post
    Engine code is 4F
  4. Re: HCK Gearbox oil
    1836 Post(s)
    The car is a 4F, not the engine... The HCK box uses VAG oil part number G 052 532 A2 and at £21.49 per litre for the 3 litres required, why use anything other than genuine?
  5. Re: HCK Gearbox oil
    May 2012
    Everywhere
    308 Post(s)
    Because Castrol developed it and it can be found cheaper !
  6. Re: HCK Gearbox oil
    Mar 2014
    Nottingham. UK
    My mistake, yes Car is 4F, Engine code is Caha.
    Do vw make there own oils? I think that's doubtful.
  7. Re: HCK Gearbox oil
    1836 Post(s)
    Are you both gambling men?
  8. Re: HCK Gearbox oil
    May 2012
    Everywhere
    308 Post(s)
    Fuch Titan Sintofluid SAE 75W80 ( G 052 911 ) in my FRK for some years now .
    Fuchs is a more specialised oil manufacturer compared to Castrol and also have codeveloped gearbox oils .
  9. Re: HCK Gearbox oil
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Personal choice. Each oil spec has its pros and cons as compared to the next when you read the test results. Its not going to kill it.
    Alan.
    VW T6 150 DSG Camper £££
  1. Question Looking for multitronic gearbox will only one code gearbox work
    By yaza01 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-10-2017, 03:39 PM
  2. Gearbox - No reverse, rattle in neutral- leaking gearbox oil. HELP!!!!!
    By robert1z in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2017, 07:00 PM
  3. 2.0 tdi Gearbox Transmission oil spec & amount for GYX gearbox ?
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-09-2015, 03:08 PM
  4. Replies: 1
    Last Post: 15-02-2015, 05:39 PM
  5. Gearbox judder (cvt gearbox)
    By Zeb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-09-2011, 02:01 PM
