Thread: Front Indicator Fault
  1. Question Front Indicator Fault
    Mar 2020
    Sandbach
    Hi Guys,
    I recently acquired a 2016 Avant, which for the most part is a great car. However, following the lashings of rain we've had, my front sidelight went on the blink, followed shortly by the indicator; the indicator at first seemed to become dimmer and just the "top" section changing to orange when the indicator was on, before becoming completely extinguished as time went on. My sidelight has since returned and functions fine, however the indicator does not light up at all on that one side.
    I understand that these are sealed units, but is there anything I can do or take a look at that my cure the problem before I beg the bank manager for permission to spend some more cash on the car to replace the entire light unit?
    Any suggestions would be most welcome (and before it's suggested, I did debate losing the other half and just spending the cash anyway but that would be a bit unfair on the kids )
    Adam
  2. Re: Front Indicator Fault
    Mar 2010
    Basingstoke UK
    Have you tried to remove the whole unit and check the wiring connection from the loom to the unit is clean and dry?
    This would be my first thought as the sidelight has started to work again. You could also try and see if you can get your local dealer to give you some sort of good will gesture again if you don’t ask.
  3. Re: Front Indicator Fault
    Mar 2020
    Sandbach
    Thanks, I think I will try and get around to that today. The weather's not been the best to have had time to take the bumper off to get to the wiring loom, and I can't visibly see the wiring from the top of the car with the bonnet open.
  4. Re: Front Indicator Fault
    Mar 2010
    Basingstoke UK
    Just remove the headlamp, from memory it’s just 2/3 screws accessible with the bonnet open. You will then have access to the loom.
  1. Indicator fault
    By 997.2Bomber in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-01-2016, 10:50 AM
  2. front indicator fault warning light
    By Houstoer1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-09-2011, 03:36 PM
  3. indicator fault
    By paullaw in forum Golf MK4 - 1999 - 2004
    Last Post: 29-04-2010, 11:26 AM
  4. A6 Indicator Fault
    By JamesWatts in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-02-2010, 10:20 AM
  5. Indicator Fault
    By Henry10 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-03-2008, 04:08 PM
