Thread: 2005 A4 Quattro 3L Cabriolet Drivers WINDOW - a puzzle for you
  1. 2005 A4 Quattro 3L Cabriolet Drivers WINDOW - a puzzle for you
    Jun 2016
    Darlington, UK
    Can you please check my diagnostic thinking on this one?
    Driver window suddenly stops working. Also does not move automatically when I open and close door (as it should). All other windows operate fine from driver's armrest control switches. All fuses OK.
    So....it's probably not a wiring problem in the loom going through the grommet at the door hinge, since problem only affects drivers' window. In any case, I cant see any obvious issues there.
    Probably not the rocker switch since the window is not doing its automatic movement.
    So I remove trim to expose the motor. No visible problems with any of wiring connections to it. Remove motor and check free movement of window up and down. It's perfect, no corrosion and all moves smoothly.
    So I convince myself that it must be the motor. I buy a used replacement from eBay. Very excited when it arrives. Fit it and .....nothing happens.
    I'm back to square 1. What have I missed? Thanks for any help.
    Steve in Darlington
  2. Re: 2005 A4 Quattro 3L Cabriolet Drivers WINDOW - a puzzle for you
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Hi buddy, sorry to p on your chips seeing as you have been struggling and spending, but having had the same issue with my b6 cabby on the drivers door , I would lay a pound to a pinch of ---- that this is a problem with one of the many wires passing through the grommet between the A pillar and door.
    I cant remember how many wires are in there but lets say a dozen, thin wires and quite thick wires all flexing constantly over the years of open/close of the door, some of the wires will break but not be instantly visible.
    Sometimes you lose window function/central lock on the one door/small speaker atop the door card/mirror movement, sometimes all of these and sometimes one or more.
    I carried out repairs on mine for different issues over the years, now you could go in and inspect and repair the particular wire/wires affected or look for a new loom, a bit fiddly but rewarding once the desired affect is realised
    Good luck
    Stuart
  3. Re: 2005 A4 Quattro 3L Cabriolet Drivers WINDOW - a puzzle for you
    Jun 2016
    Darlington, UK
    Thanks Stuart. Well, looks like it's time to start doing a bit of probing to see if there is any obvious break. That will keep me out of mischief for a while.
    Any other theories are most welcome.
    Best wishes, and thanks again,
    Steve
  4. Re: 2005 A4 Quattro 3L Cabriolet Drivers WINDOW - a puzzle for you
    1835 Post(s)
    You need to do a diagnostic scan of the convenience system and drivers door electrics. You also need to make sure the coding in the new door controller (the motor) is the same as the old one.
  5. Re: 2005 A4 Quattro 3L Cabriolet Drivers WINDOW - a puzzle for you
    Jun 2016
    Darlington, UK
    Thanks for that. The car is in independent repair shop today for other reasons (broken front coil, which I didn't fancy attempting), so have asked them for a scan and any advice.
    The used motor I got on eBay looks identical in all respects to original, but I may change back to eliminate that concern, especially as my original one looks a lot smarter! :-)
    Thx
  1. 2005 1.8T B7 Cabriolet - Window Switch Problems
    By Skezza in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-12-2018, 12:41 PM
  2. Question Drivers window regulator A4 cabriolet
    By leebarkshire in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 04-02-2017, 06:59 PM
  3. 2005 S4 Cabriolet - Sat Nav Upgrade
    By sjwdavies in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-05-2014, 12:42 PM
  4. Question Frozen A4 Cabriolet Drivers Window
    By Paultr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-02-2009, 11:27 AM
  5. Electric window puzzle - 1994 cabriolet
    By ping_zero in forum 80 - 90
    Last Post: 27-11-2006, 12:04 AM
