Thread: starter motor problem - P305300 open circuit terminal 50
  1. starter motor problem - P305300 open circuit terminal 50
    Oct 2009
    corsham wiltshire
    Hi All , can anyone please help? Im getting the orange coil warning light and start stop de-activation warning come up when starting my A8 3.0 TDI D4. The car starts ok but sometimes it takes a second press as it stops turning over on the first one after a second or so. Tried clearing the fault but it comes up again when starting the engine. checked the battery, it has plenty of charge .
    I ran an obd scan and P30500 code comes up with details of "starter solenoid short to ground/open circuit terminal 50" . Is this solenoid on the starter motor itself or on a fuse board elsewhere, i.e. necessitating replacement of starter motor or just a solenoid block?
    Just some background to this - checked where the starter is located and the big earth return cable on the starter was loose and was arcing out , would this have cooked the relay ?
    Simon
  2. Re: starter motor problem - P305300 open circuit terminal 50
    Oct 2019
    Peterborough, England
    23 Post(s)
    always worth changing the solenoid/relay.
    Not sure where it is, it should be reachable..... (famous last words)
    Arcing would not have helped the relay.
  3. Re: starter motor problem - P305300 open circuit terminal 50
    Oct 2020
    USA
    Hi mate. Have you found the solution? i've just got problem with my 2015 A8 4.0L.
  4. Re: starter motor problem - P305300 open circuit terminal 50
    Oct 2020
    USA
    Quote Originally Posted by simonavo View Post
    Simon
  1. P2100 Throttle actuator control motor circuit open FAULT MIL LIGHT
    By petrolhead63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-09-2018, 10:06 PM
  2. Fault code 01533 - Terminal 56 (High Beams) 36-00 - Open Circuit
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-08-2016, 08:11 PM
  3. Help: Fault code IMRC- Inlet Manifold Runner circuit, open circuit.
    By OliB in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 04-12-2010, 11:47 AM
  4. Please Help Starter motor problem ?
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 28-07-2010, 12:12 PM
  5. Starter motor problem
    By eve1973 in forum Touran - Sharan - Caravelle
    Last Post: 11-11-2009, 09:15 PM
