Thread: Leaking Rear Shock? Opinions? Pic included
  1. Leaking Rear Shock? Opinions? Pic included
    Nov 2016
    Ireland
    14 Post(s)
    Sometimes I notice the drivers rear of my Golf V is sitting lower than the passenger side and when I measure it by sticking my hand in between the top of the tyre and the wheel arch there is a definite difference. Other times, it looks and is identical. Anyway, I was under the rear investigating today and noticed what I think was oily fluid under the top plastic cover piece on this drivers side shock. The location of where I can see this fluid is indicated in the picture I posted, I can push that little plastic collar thing up off the chock and then I can see a small amount of fluid at the top of it, it's not a lot but is there, the passenger side is dry and doesn't have this.
    The picture posted is the exact brand and part no. Monroe 23979 of shock that's on my car, is this likely to be oil or just a residue. I notice this Monroe shock is a "Twin-Tube" type (new to me) as opposed to a Monotube shock (which is what I thought all shocks were), anyway, is the oil I see under that collar likely to indicate the shock is goosed, or is it just misty residue not necessarily meaning the shock is goosed?
    I didn't fit these shocks, were on it when I bought the car but there's at least 40k miles on them as that's the miles I've put on the car since buying.
    The car (and it's shocks obviously) recently passed the Nct which is the equivalant of the Uk Mot and nothing was mentioned about shocks so do I just replace or can is there anything else I can do to test the shock before condemning it. If I pull it off the car would I see more?
  2. Re: Leaking Rear Shock? Opinions? Pic included
    1836 Post(s)
    There is a VAG Technical Product Information notice about this which tells VAG dealers that if they replace a damper for that amount of oil they will be “redebited” for the costs and it also states that a small amount of oil “sweating” is actually beneficial to the life of the piston rod seal. A leaking damper will not affect the ride heigh, take the damper of and the height will be the same, what does affair the it and is common on the Golf 5 is broken rear springs right down inside the arm where you can’t see the break and disintegrate is bumps stops
  3. Re: Leaking Rear Shock? Opinions? Pic included
    Nov 2016
    Ireland
    14 Post(s)
    That's interesting. I guess mine isn't leaking then so, I think mine could only be described as a slight residue or misting at best and around the seal area so seems ok.
    I'll just keep an eye on it, funny the other side doesn't appear to be wet in any way though.
    The springs seem to be in good condition, not rusted and no crus built up at the base of the spring, it's actually hard to see down to the bottom coil of the springs even with the wheel off. I'll have better view when replacing the suspension arms / bushings.
    Cheers for the helpful info once again, Crasher.
  4. Re: Leaking Rear Shock? Opinions? Pic included
    1836 Post(s)
    Quote Originally Posted by TdiBlacky140 View Post
    We use a mirror on a stick
  1. Please Help Leaking rear shock absorbers on Feb 2008 Estate having only done 60K!!!!!
    By Baldone in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-04-2012, 01:05 PM
  2. Please Help Rear left suspension creaking (Audio Included)
    By joshhh in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-01-2012, 07:16 PM
  3. Please Help Do i need a new EGR? looks like the solenoid is leaking, pics included :)
    By discophil in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-10-2011, 08:22 PM
  4. Leaking Rear Shock
    By TonyMc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2011, 11:49 AM
  5. Newbie Polo Owner! Advice And Opinions! Pics Included
    By pop80_uk in forum Polo - Derby - Lupo - Fox
    Last Post: 03-07-2007, 08:26 AM
