Thread: Leaking Windscreen Washer bottle
Results 1 to 10 of 10
  1. Leaking Windscreen Washer bottle
    Nov 2018
    Tamworth
    19 Post(s)
    Hi all,
    Recently noticed that the washer bottle has needed filling up more & more often.
    Today needed 2 litres after filling it up yesterday and there is now a wet patch by the drivers side front wheel.
    I'm guessing it's a split pipe but has anyone had something similar happen and could offer any suggestions about where to start looking?
    Hopefully it's not a full bumper off, wheel liners out, strip down......
    Thanks in advance.
    Andy.
  2. Re: Leaking Windscreen Washer bottle
    36 Post(s)
    835 Post(s)
    It is a full strip down to replace and we have had to do a few.
  3. Re: Leaking Windscreen Washer bottle
    Nov 2018
    Tamworth
    19 Post(s)
    Thanks for the reply.
    Oh well, I'll get the chance to have a good look around while I'm in there.
    Andy.
  4. Re: Leaking Windscreen Washer bottle
    Jan 2012
    Rustington, West Sussex UK
    6 Post(s)
    66 Post(s)
    Quote Originally Posted by AndyN01 View Post
    Andy.
    Just done mine, 2 metres of rubber hose. Removed as much of the old corregated original as possible but VW put it inside the electrical loom conduit, why, why, why! Bumper cover undone but left propped on a rolling seat and only the drivers side pulled aside to reveal the motor and pipe routing. Inner wheel arch cover partially undone and pulled out of the way with a bungy after lower quarter section removed. Wrapped looms carefully undone / cut with a Stanley blade and retaped after new hose routed (old pieces removed). Fairly easy but fiddly job and took me an hour and a half.
    Mad Mitch
  5. Re: Leaking Windscreen Washer bottle
    Nov 2018
    Tamworth
    19 Post(s)
    Hi Mitch,
    Quick question, which rubber hose did you get? There's so many on a well known auction site that I'm baffled .
    And did you need any in line connectors? One way valve?
    Thanks in advance.
    Andy.
  6. Re: Leaking Windscreen Washer bottle
    Jan 2012
    6 Post(s)
    66 Post(s)
    Hi Mitch,
    Thanks in advance.
    Andy.
    Just a 2 metre VW beetle 5/32 rubber tube around 4 on ebay. All my connectors were fine as it was perished pipework that was leaking right near to the washer bottle and where the pipework enters the Scuttle area. Was fiddly getting the hose onto the bonnet washer jet from inside the hole, very tight. I have some pics but not the best illustrations of the job. PM me your email address if you want them. The hose itself loops from the washer bottle almost back on itself following the inner framework into the engine then disappears inside the large loom conduit that runs past the upper part of the water bottle in 2 sections bending around the top of the coolant expansion tank before it hairpins into the bulkhead slot under a plastic junction cover then routes around the top of the Scuttle attaching to the connector of the first washer jet in the bonnet which alao branches off to the second jet.
    Mad Mitch
  7. Re: Leaking Windscreen Washer bottle
    Nov 2018
    Tamworth
    19 Post(s)
    Great, I'll get ordering and get the tools out next week - if it stays dry.
    Andy
  8. Re: Leaking Windscreen Washer bottle
    Nov 2018
    Tamworth
    19 Post(s)
    Update....
    It looks like the leak is coming from the pump itself? Or maybe the rubber grommet?
    I can't see any water coming from the lines themselves,
    Could it be the pump? Quite happy to have used one - where from?
    Thoughts and suggestions welcome.
    TIA.
    Andy.
  9. Re: Leaking Windscreen Washer bottle
    Nov 2018
    Tamworth
    19 Post(s)
    Further update.
    New pump from these folks:
    Windscreen Washer Pump Front Rear Fits VW Passat (B6) 1.9 TDI Diesel (2005-2011) | eBay
    Fitted fine but if you get one note that the female pipe connectors need to be squeezed very tightly to get the plastic locking clips to locate. I popped a small cable tie round to make sure.
    BUT there was a split in the rear washer pipe where it goes around the coolant expansion tank. All sorted with several turns of PTFE and wrapped tightly with self amalgamating tape.
    Andy.
  10. Re: Leaking Windscreen Washer bottle
    Jan 2012
    6 Post(s)
    66 Post(s)
    Further update.
    Andy.
    That's good but just be mindful that the OE pipework once it reaches the splitting stage is already compromised and is likely to split in other parts of its length. It is the type of plastic that becomes brittle with age and therefore replacing the whole length while you have the car partly dismantled would have been a more permanent solution. Be prepared for more leaks at some point in the nearer future.
    Mad Mitch
  1. how to fix leaking washer bottle
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-05-2015, 02:55 PM
  2. Mk5 windscreen washer bottle...leaking
    By rush in forum Golf MK5 - 2004 - 2009
    Last Post: 26-05-2012, 11:04 AM
  3. Leaking Windscreen Washer Bottle
    By vwbolton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-01-2010, 06:32 PM
  4. windscreen washer bottle
    By VAG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2009, 07:01 PM
  5. Please Help windscreen washer bottle
    By jacohelp in forum Polo - Derby - Lupo - Fox
    Last Post: 01-02-2009, 06:04 PM
free web
stats
