Thread: Clonk when changing gear
  1. Clonk when changing gear
    Oct 2019
    Hertfordshire
    Can any body give me some ideas on where to look for this issue
    When driving the car from 1st to second I hear this loud clonk in between from pulling off. Seems to be getting worse I can feel it inside the cabin around the passenger side gearbox tunnel. Actually feels like a joint clicking it's horrible.
    I've had the car in the air and checked the arms, joints and mounts can't find nothing any ideas please
    Sent from my CLT-L09 using Tapatalk
  2. Re: Clonk when changing gear
    1840 Post(s)
    There are all sorts of possibilities, has anything been done recently?
  3. Re: Clonk when changing gear
    Oct 2019
    Hertfordshire
    Just replaced the driveshaft on passenger side in November but has been fine. Its only recently started doing it the last few weeks
  4. Re: Clonk when changing gear
    1840 Post(s)
    When you changed the shaft, how did you get it out and did you replace every single fastener you touch with genuine and torque to the correct spec? Did you check the CV splines in the hub to see if they had any slack? Some CV’s are very loose in the splits and VAG even state you should use bearing fit liquid (a type of thread lock) to prevent spline shifting. If you reuse and insufficiently torque the centre bolt, this can also cause spline shift. Also some cheap recon driveshafts can be appalling quality, we will only fit OE GKN/Lobro shafts or joints.
  1. Question gear not changing??
    By checkmate in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-07-2009, 01:33 PM
  2. Please Help vibration when changing gear
    By arman123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-02-2009, 01:59 PM
  3. Gear changing
    By moptisam2 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-08-2008, 08:33 AM
  4. Question Rattle Clunk sound from gear box when changing gear?
    By jasonocallaghan in forum Golf MK5 - 2004 - 2009
    Last Post: 27-06-2008, 12:20 AM
  5. Squeek when changing gear ?
    By tennentsfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2008, 07:34 PM
