Thread: VW Caddy 2016 ABS error codes after steering rack replacement
  1. VW Caddy 2016 ABS error codes after steering rack replacement, now fixed.
    Aug 2007
    telford
    Hi I have had a VW Caddy brought to me after the steering rack was replaced with a reconditioned unit, the original rack was damaged due to vehicle running over a pot hole, on delivery to me I had several error code no adaptions had been carried out, I am now down to the following two fault codes in the ABS module, The Databus error code of 8198 is the one that is really got me, I can not find on info on the meaning of this error code.
    If I try to carry out steering angle sensor basic settings in ABS module I get a command stating that I am not able to carry out basic settings.
    Full log as follows.
    Edit I have now changed adaption settings in steering assist, as a result I now only have the basic settings fault in ABS, Databus fault has now cleared.
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 52 5F 61
    VIN: WV2ZZZ2KZGX062526 Mileage: 82470km-51244miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    4C-Tire Pressure II -- Status: Sporadic communication error 1000
    5F-Information Electr. -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    Address 01: Engine (J623-DFSD) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 016 HA HW: 04L 907 309 K
    Component: R4 2,0L EDC H20 1804
    Revision: 8AH20---
    Coding: 011D0012042515090000
    Shop #: WSC 35110 790 50316
    ASAM Dataset: EV_ECM20TDI01104L906016HA 001003
    ROD: EV_ECM20TDI01104L906016GR_001_VN35.rod
    VCID: 6FAE305FB69680374C-803A
    1 Fault Found:
    17158 - Implausible Data Received from ESP Control Module
    U0416 00 [047] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 82450 km
    Date: 2020.03.05
    Time: 12:12:30
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 39 °C
    Intake air temperature: 47 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 11.920 V
    Unlearning counter according OBD: 40
    Drivetrain coordinator: ACC fault status-Bits 0-7: 0
    Drivetrain coordinator: brake fault status-Bits 0-7: 4
    Drivetrain coordinator: brake function status-Bits 0-7: 0
    Drivetrain coordinator: brake function status-Bits 0-7: 32
    Acceleration: 0.000 m/s²
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 063 J HW: 02E 927 770 AL
    Component: GSG DSG AG6 531 4918
    Revision: 06253104 Serial number: 00001509210393
    Coding: 0000020
    Shop #: WSC 35110 377 00146
    VCID: 1D723A97C4BA42A7AE-8048
    2 Faults Found:
    18036 - Powertrain Data Bus
    P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 82450 km
    Time Indication: 0
    Date: 2020.03.05
    Time: 11:09:58
    18261 - Powertrain Data Bus
    P1853 - 000 - Implausible Message from ABS Controller - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Reset counter: 39
    Mileage: 82450 km
    Time Indication: 0
    Date: 2020.03.05
    Time: 11:45:43
    Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
    Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
    Component: ESC H05 0132
    Revision: 00000000 Serial number: 42935000000709
    Coding: 1479409BB268A480287A02784D8825D379F100
    ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
    ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
    VCID: 3FCEA01FA67630B79C-806A
    2 Faults Found:
    0295 - Steering angle sensor
    B1168 54 [137] - Missing Calibration / Basic Setting
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 109
    Mileage: 82475 km
    Date: 2020.03.06
    Time: 10:11:37
    8198 - Databus
    U1123 00 [009] - Received Error Message
    [ACAN: LH3_Sta_DSR signal failure value]
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 109
    Mileage: 82475 km
    Date: 2020.03.06
    Time: 10:11:37
    Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
    Part No SW: 1K8 907 426 AF HW: 1K8 907 426 AF
    Component: AC Manuell H20 0808
    Revision: 00001002
    Coding: 0010004003
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_VW32.rod
    VCID: 77BE083FCEC6C8F794-8022
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
    Component: BCM PQ35 M+ 122 0183
    Revision: BD122001
    Coding: 491A0A3E8025E16B088800829400816403D10008426F832064 80C7000041
    VCID: 73A63C2FD2BEA4D7A8-8026
    Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer 05101 27 0512
    Coding: 009795
    Subsystem 2 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
    Component: RLS 111115 03 37 0059
    Coding: 0228DD
    Subsystem 3 - Part No: 7N0 951 172
    Component: Sensor, DWA 0 005 0502
    Coding: 000000
    Subsystem 4 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Coding: 000000
    Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
    Part No SW: 1K8 919 465 HW: 5Q0 919 283
    Component: PARKHILFE 4K H10 0479
    Revision: -------- Serial number: 39291530002035
    Coding: 0001050011
    ASAM Dataset: EV_EPHVA14VW364GP00 001006
    ROD: EV_EPHVA14VW364GP00_VW36.rod
    VCID: 76A0053BC9CCB1FF8F-8022
    Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
    Part No SW: 7N0 907 572 A HW: 7N0 907 572
    Component: ACC Bosch PQx H03 0111
    Serial number: 09111577090049
    Coding: 00001000FE0339
    ASAM Dataset: EV_ACCBEGVW361 001004
    ROD: EV_ACCBEGVW361_VW32.rod
    VCID: 3424FF339F30E3EF71-8060
    5 Faults Found:
    1071 - Databus
    U1123 00 [008] - Received Error Message
    [FAULT_CIS_AXV_INVALID]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 148
    Mileage: 82450 km
    Date: 2020.03.05
    Time: 11:46:07
    Control Module temperature: 38 °C
    Voltage terminal 15: 14.5 V
    Vehicle speed: 0.00 m/s
    Acceleration: 0.00 m/s²
    1058 - Databus
    [FAULT_CIS_ECD_NOTAVAILABLE]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 108
    Mileage: 82450 km
    Date: 2020.03.05
    Time: 11:09:58
    Control Module temperature: 24 °C
    Voltage terminal 15: 11.7 V
    1059 - Databus
    [FAULT_CIS_ESP_FAIL]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 108
    Mileage: 82450 km
    Date: 2020.03.05
    Time: 11:09:58
    1075 - Databus
    [FAULT_CIS_YAW_INVALID]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 82450 km
    Date: 2020.03.05
    Time: 11:49:05
    Control Module temperature: 37 °C
    Voltage terminal 15: 14.2 V
    Vehicle speed: -0.53 m/s
    Acceleration: -1.21 m/s²
    0274 - Databus
    U1121 00 [008] - Missing Message
    [FAULT_TIMEOUT_mLW_1]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 82450 km
    Date: 2020.03.05
    Time: 11:09:58
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 2K5 959 655 A HW: 2K5 959 655 A
    Component: VW10Airbag00K 008 0016
    Revision: -------- Serial number: 003QX000SW5+
    Coding: 00000000000000000000000000000000304B
    ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
    ROD: EV_AirbaVW10BPAVN750_VW12.rod
    VCID: 3A38D10BBD54159FAB-806E
    Crash sensor for side airbag: driver side:
    Serial number: 3497ARB405R3L51QQ1GY
    Crash sensor for side airbag: front passenger side:
    Serial number: 3507ARB40653LKH0HPKT
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3517ARB405N3LF5MJHK3
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3527ARB405N3LF5MDQ6-
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 521 FF HW: 5K0 953 569 BB
    Component: LENKS.MODUL 018 0230
    Revision: FF010042 Serial number: 20151022300513
    Coding: 5880160010
    ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
    ROD: EV_SMLSNGVOLWSR8C.rod
    VCID: 75A20237D4CABAE786-8020
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 2K5 920 976 A HW: 2K5 920 976 A
    Component: KOMBI H04 1009
    Serial number: 00000000000000
    Coding: 480A011200
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
    ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 BG HW: 7N0 907 530 AN
    Component: J533 Gateway H56 1674
    Revision: H56 Serial number: 031115F1000671
    Coding: 357431
    Shop #: WSC 00000 288 1392019
    VCID: 76A0053BC1CCB1FF8F-8022
    1 Fault Found:
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 82450 km
    Time Indication: 0
    Date: 2020.03.05
    Time: 11:45:48
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 1009
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6A98214B8D74651F1B-803E
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
    Part No SW: 2K5 959 701 HW: 2K5 959 701
    Component: Tuer-SG 009 2144
    Coding: 0131632
    VCID: 71AA362768A296C75A-8024
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 R
    Component: EPS_ZFLS Kl. 000 3501
    Revision: 00H22000
    Shop #: WSC 40132 002 1048576
    VCID: 393ACE0770521E87A2-806C
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 2K5 959 702 HW: 2K5 959 702
    Coding: 0131632
    VCID: 72A8392B6DA4ADDFA3-8026
    Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
    Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
    Component: MU-S-ND-ER H22 0245
    Serial number: VWZAZ2R8008218
    Coding: 06330701BE00000011111101008808001F0100C600200100CF
    ASAM Dataset: EV_MUStd4CTSAT 001022
    ROD: EV_MUStd4CTSAT_SK26.rod
    VCID: 210A066730C266478A-8074
    Data medium:
    Subsystem 1 - Part No SW: 3G0 919 866 M HW: -----------
    Component: ECE 2016 --- 0521
    Serial number: --------------------
    Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
    Component: Batt.regelung H56 1674
    Coding: 030F1873
    VCID: 71AA3627A8A296C75A-8024
    Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    Serial number: 32299I04141491893978
    End----(Elapsed Time: 01:18, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    Address 19: DTCs cleared
  2. Re: VW Caddy 2016 ABS error codes after steering rack replacement
    Aug 2007
    telford
    sorted this problem, the steering rack was sent from part supplier with no software installed on rack control module.
    Revision: 00H22000
    the component section does not show a software version, something to look out for
  1. Replacement Steering Rack has changed steering
    By xandertarr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-04-2017, 10:46 AM
  2. Please Help Need a steering rack replacement.
    By mistermoo in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 06-02-2016, 03:41 PM
  3. Please Help A3 steering rack replacement
    By Marcopolo1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-01-2014, 10:58 PM
  4. Replacement Steering Rack
    By hidnmine in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-05-2012, 01:12 PM
  5. Steering Rack replacement
    By Wirral Allroad in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-03-2010, 05:43 PM
